Author Topic: suspension problems help please  (Read 1240 times)
Offline Ryan
  • Scotland
« on: 04 June 2005, 12:25 »
hi there
   i have lowered my golf on 55mm lowering springs from venom motorsport but now that i have installed them the cup on top off the inner wing sits about 5mm off the wing. so when i raise the car the strut drops back down but when i lower it the cup on top sits proud.
   what have i done wrong?  i tightened everything up as tight as it would go. someone please help as the car is going for it's MOT next week and wont pass with this problem.
cheers ryan
WANTED:: 16v crankshaft pulley and rear windescreen washer bottle
Offline Rain
  • forum irregular
Re: suspension problems help please
« Reply #1 on: 04 June 2005, 17:10 »
not sure what you mean by cup do you mean the top mounts?? picture might be handy
Offline Mr Blue
« Reply #2 on: 04 June 2005, 19:20 »
is this for a mk2?
MOT will pass but sounds like your topmounts need changing if they stretch out quite abit. Use VAG mounts only.
Offline Ryan
  • Scotland
« Reply #3 on: 04 June 2005, 20:00 »
yeah i mean top mount i think? :undecided: where the strut top passes into the inner wing and you have the nut that threads on and has the plastic cap that sits on top in the engine bay. the mount there that sits on the inner wing will not sit flush and is raised alround by about 5mm.
ryan
Offline Mr Blue
« Reply #4 on: 05 June 2005, 13:52 »
you get that when you lower these old bangers :grin: mines the same. top mount sticks out abit. if it doesnt cause problems then it should be arite.
