Author Topic: AGU engine Help plz  (Read 3280 times)
Offline topher
  • Administrator
  • fully functioning
Re: Help plz
« Reply #20 on: 22 April 2012, 21:04 »
aum don't have them
Offline inggti
Re: Help plz
« Reply #21 on: 23 April 2012, 17:44 »
Ok still having Problems. Just used a different ignition amp and still te same. I even put the 3bar pressure reg bak on. Only thing next is fuel pump. Any other ideas
Offline xxChrisxx
Re: Help plz
« Reply #22 on: 23 April 2012, 20:00 »
Drained battery and misfires?
Check your earth leads. Specifically the one from under the battery to the side of the block.
Probably not that, as you'd get a short to ground fault. But it's free and easy to do.
« Last Edit: 23 April 2012, 20:03 by xxChrisxx »
Offline inggti
Re: Help plz
« Reply #23 on: 23 April 2012, 20:51 »
Yeah drained battery and now miss fires but not for first few minutes of driving but then holds bak and missfires
Offline inggti
Re: Help plz
« Reply #24 on: 25 April 2012, 08:27 »
Changed fuel pump and ignition amp and still the same
Offline inggti
Re: Help plz really desperat
« Reply #25 on: 26 April 2012, 16:45 »
Ok changed all that. And still the same. Sat in car with it ticking over. Once it reached 80 on temp. It splutted revs dropped to about 500 then rose to 1400 then back to 500 and then cut out. I now I'm a pain and I very much love my golf but she is testing me to the extreme. Plz any other info. I am truly greatfull
Offline topher
  • Administrator
  • fully functioning
Re: Help plz
« Reply #26 on: 26 April 2012, 21:41 »
can you restart it right away or do you have to wait for it to cool down?
Offline inggti
Re: Help plz
« Reply #27 on: 26 April 2012, 22:17 »
It starts straight away well a few seconds of holding the key. Some times a bit of accelerator pedal
Offline topher
  • Administrator
  • fully functioning
Re: Help plz
« Reply #28 on: 26 April 2012, 22:20 »
don't suppose that temp sender code popped back up yet?
Offline inggti
Re: Help plz
« Reply #29 on: 01 May 2012, 22:45 »
No it hasn't. Still the same. I ran out of petrol earlier. And I now it wouldn't start straight away. But it sounded as if it wasn't firing. My mate said change the crank sensor?? I now wot it is but could this b the cause of my problem
