Author Topic: AGU engine Help plz  (Read 3278 times)
Offline inggti
AGU engine Help plz
« on: 22 April 2012, 15:40 »
Nice yesterday my agu has been holding bak and then going then it will cut out but start after a few seconds. I plug it into snap on machine and all it said was temp sensor and battery had died. I've changed spark plugs and rocker gasket cause there was bit of oil round spark plug. And now had second hand coil paks. But still hesitating. And wen u foot it to the floor it's like a kangaroo. Only thing is I did run it really low on petrol last white notch past red. Plz plz any help
« Last Edit: 02 May 2012, 11:50 by richw911 »
Offline Big Tone
Re: Help plz
« Reply #1 on: 22 April 2012, 15:47 »
Dont like the sound of second hand coils! Would have thought you would have a misfire code if that was the cause.
Change temp sender, easy and cheap.
I would usually say boost/vac leaks, but you would have thought you would log a code, can you pressure test it?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline inggti
Re: Help plz
« Reply #2 on: 22 April 2012, 15:49 »
I'll change Ensor tomorrow and no other codes. And air got the stuff to leak test. It's only been like it since yesterday. Really wen it gets upto temp. From cold it's okay
Offline topher
  • Administrator
  • fully functioning
Re: Help plz
« Reply #3 on: 22 April 2012, 16:19 »
being an AGU my gut says ignition amp, but a dying fuel pump can cause similar behaviour.
Offline Toby
  • Car - less
Re: Help plz
« Reply #4 on: 22 April 2012, 16:22 »
this!
 :wink:
Currently down under
Offline inggti
Re: Help plz
« Reply #5 on: 22 April 2012, 17:14 »
I ope it's as simple as that. Just don't now we're toget ignition amp from
Offline Toby
  • Car - less
Re: Help plz
« Reply #6 on: 22 April 2012, 17:56 »
ebay!?
iv got a spare! ; :wink:
Offline wretch20vt
Re: Help plz
« Reply #7 on: 22 April 2012, 18:05 »
and me lol
Offline inggti
Re: Help plz
« Reply #8 on: 22 April 2012, 18:38 »
Wish u lived by me. And there ain't any on ebay
Offline inggti
Re: Help plz
« Reply #9 on: 22 April 2012, 19:06 »
Has any body got pic of ignition amp so I know wot I'm looking for
