Author Topic: Urgent help needed with throttle body  (Read 3493 times)
Offline patc
« on: 22 April 2012, 12:28 »
Help please.  Not with my golf but with my mk1 mx5.
I was cleaning the throttle body with a spray and the plastic straw shot off into the intake!!
I cant see it.  I have tried a long thing with sticky tape on the end and a hoover but nothing!
Whats the worse that could happen if i started the car??
 :sick:
PatC
Golf GTI MK3 Anniversary Edition
Offline Chris#101
Re: Urgent help needed with throttle body
« Reply #1 on: 22 April 2012, 12:37 »
How long was the 'straw' you need to figure out if its short enough to of made its way  down one of the runners!?  :wink:
How ever having helped turbo a mk1 mx5 myself I know that taking the inlet manifold off is a very easy and doesnt take long atall
you'd be an idiot to leave it in there  :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline patc
« Reply #2 on: 22 April 2012, 12:42 »
Its like the straws you get with a can of wd40.
Should my local garage be able to get the inlet manifold off quite easily then?
PatC
Offline clipperjay
« Reply #3 on: 22 April 2012, 12:44 »
Agreed  :laugh:
Offline Chris#101
« Reply #4 on: 22 April 2012, 12:47 »
Personally I would of said that there wouldnt of been enough room in the plenum for the straw to of turned 90degrees and headed down a runner.
I assume youve shon a torch down there to have a look?
*Take your throttle body off, 4 bolts on each corner from what I remember!
*Get a torch and have a look, chances are youl see it laying in the plenum
Offline patc
« Reply #5 on: 22 April 2012, 12:49 »
Cant get the body at the mo.  Only 2 bolts out from the 4.  Had a look with a thin torch but cant see sweet fa to be honest.  Gonna have to ask local mechanic tomorrow.
PatC
Offline Sprakie2008
« Reply #6 on: 22 April 2012, 14:44 »
average hourly rate of a mechanic: £36.00 p/hour
Average price of a haynes manualo: £18.00
For everything else, theres Golfgti.co.uk
in other words, go get yourself a haynes manual for your car, and follow the instructions on there to take your inlet manifold of and save yourself some coin in the short, and the long run!
Mk3 Mad!
Offline gti gaz
« Reply #7 on: 22 April 2012, 15:32 »
think these come off easy enough if your conferdent enough give it a go
 Any one in cornwall lets sort more meets!!!!
Offline Seanl
« Reply #8 on: 22 April 2012, 19:53 »
Stop being such a girl driving an MX5, and just go for a good run in it to see what happens!  :lipsrsealed: :laugh:
Offline patc
« Reply #9 on: 23 April 2012, 17:31 »
All sorted!!
Have a manual but had to work today.
Local mechanic got the throttle body off and was able to see it and retrieve with a long thing with sticky tape on the end.
And as my mechanic said "don't do it with a f@@king straw again!"
Cheers for people's input
PatC
