Author Topic: how do i remove the green cover to reveal the timing mark  (Read 1949 times)
Offline off_the_cuff
as my cars not starting i thought i should check my timing, set it to TDC and checked the timing mark under the plug and its nowhere to be seen :S can any1 tell me how to take the green cover off please so i can have a proper look, i dont have the proper tool to take it off so any alternative methods would be great lol
Offline gasketface
Re: how do i remove the green cover to reveal the timing mark
« Reply #1 on: 21 April 2012, 21:09 »
If you mean the green cover on the end of the box then DO NOT REMOVE !!.
You need the plastic plug on top of the box,near to where it joins the engine  :smiley:
« Reply #2 on: 21 April 2012, 22:18 »
i mean the cover that covers the bit to see the timing mark, theres a white plug on top and a green screw out bit
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 22 April 2012, 01:26 »
just pull the plastic bit on top of the box
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #4 on: 22 April 2012, 01:28 »
the white bit just pops off but the green bit seems to screw in n i dont want to break it lol
Offline CJA321
« Reply #5 on: 22 April 2012, 02:22 »
You dont need to take the green part out. take the clear/white part and you should see it on the flywheel.
Timing marks on the belt side are way more important to check
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #6 on: 22 April 2012, 11:25 »
Regarding the timing belt, you only need the timing marks on the belt side,  the marks on the flywheel are for ignition timing or finding TDC for other reasons.  If its all lined up on the belt side, the flywheel also be lined up.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline javalin
« Reply #7 on: 23 April 2012, 10:56 »
use the flywheel marks - I find the timing marks on the cogs vague at best, first attempt doing it with the cog markers was way out.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #8 on: 23 April 2012, 17:42 »
ok so i was out today checking my timing and im abit confused, i have the letters on the top wheel with the white mark on the inside, but as i was turning the wheel i noticed theres a 2nd white mark on the opposite side with a circle mark on the outer edge, which 1 should i go by?
also when you turn the engine by hand should it turn smooth or stop after every cylinder? if that makes sense?
