Author Topic: Rear Wiper Motor Issues??  (Read 968 times)
Offline andrew.0
« on: 21 April 2012, 15:19 »
Hello All
just been down the scrap yard to replace the rear wiper motor,  but it leaks.
The leak seems to be coming from corrosion in the motor on the bit that is inside the car, so facing into the boot, has anyone else had a similar problem?
the original motor on it has exactly the same corrosion on the plastic, and sends the windscreen washer spraying into the boot...
Many ThankS!
Offline richw911
Offline andrew.0
Re: Rear Wiper Motor Issues??
« Reply #2 on: 22 April 2012, 00:00 »
Ah, thank you!
