Author Topic: Volksbits door handles and safety plates  (Read 3300 times)
Offline j_s
« on: 03 June 2005, 21:01 »
Hi guys
Are Volksbits handles proper VW handles or copies? What i'm really after are some that don't get so worn looking (after 17 years I suppose they would but still)
Also as i'll be replacing the handles I was thinking of adding the Volksbits safety plates, are they worth getting?
Seen a few pics of them but not up close and they look ok.
James
Offline Rain
  • forum irregular
Re: Volksbits door handles and safety plates
« Reply #1 on: 03 June 2005, 21:12 »
look like originals to me but id say email them and ask unless someone here has purchased them as for the plates for the doors there a brilliant idea even if they look awful as they stop some idiot opening your door with a screw driver in 5 seconds flat.
Offline gibby
« Reply #2 on: 04 June 2005, 00:42 »
I'd recommend door plates, not necessarily from volksbits but in general, I found out the hard way as to why they are a good idea.  :angry:
......now officially dubless.
Offline Rain
  • forum irregular
« Reply #3 on: 04 June 2005, 09:14 »
same here i know have those silly big hangles of ebay on because they hide the damage better than old ones and the plates sit about 5mm off the door if i use them because its al bent up :S
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 06 June 2011, 22:54 »
Think you'll find they Volksbits ones are copies..
You can buy some OEM ones from VW classic in Germany... But they aren't cheap...
For More Info Click To See;
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 06 June 2011, 23:04 »
I take it they are NLA lol
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #6 on: 06 June 2011, 23:09 »
Nah they have recently added a couple of the lock versions but I think they are 40.00 euro each...
UK dealers don't seem to have any tried to order a couple ages ago!!
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 06 June 2011, 23:11 »
make that 54.00 Euro each...
Offline cняis
« Reply #8 on: 07 June 2011, 00:38 »
TPS have genuine in stock, about £30 each IIRC (9 months ago)
if you cant afford new genuine ones then head over to a scrappy/breakers as the genuine ones simply last and work straight away. Pattern ones are cheap for a reason. The trigger mechanism wears out within 6 months so you cant open the door. Oh and they snap if someone pry's them with a screwdriver. plus the lock barrel disintegrates if someone jams a screwdriver in it. AVOID!
Again like Gibby I found out the hard way. Use genuine handles and armour plates (any make plates will do)
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 07 June 2011, 00:41 »
I had one snap on me when opening a door...
If I get any Chinese ones now they go straight in the BIN!!
Not a lover of armour plates but do understand why peeps use them...
