Author Topic: eibach rear ARB fitting problems  (Read 1894 times)
Offline colz1234
« on: 19 April 2012, 17:52 »
car was in garage today to get front and rear ARB's fitted, front went on no problem, but they couldnt fit the back one
the clamps they supplied that go around the subframe are too short and wont go all the way round, apparently most golf rear subframes are circular but mine is triangular and too wide, so cant fasten it to anything, has anyone else had this problem?
im not even sure where to get the clamps to as my mechanic said he didnt even know what they were called
has anyone experienced this before? or could help me to fix my problem? i can take some pics if it helps
thanks
Offline mcgee9t2
Re: eibach rear ARB fitting problems
« Reply #1 on: 19 April 2012, 17:53 »
sure they just attach to the bottom of the strut mount
EDIT:
just realised you mean the middle part were it clamps, sure on mine its circular aswell. so cant help you with regards to were you would get triangle ones from. sorry
« Last Edit: 19 April 2012, 17:55 by mcgee9t2 »
Offline JimBR
« Reply #2 on: 19 April 2012, 18:59 »
Pretty sure my rear axle is triangular too.
Offline colz1234
« Reply #3 on: 19 April 2012, 20:56 »
have you got a rear ARB fitted? and if so how did you do it?
Offline rench
« Reply #4 on: 19 April 2012, 21:44 »
im having eibach front and rear fitted tommorrow, will let you know if my rear axel is triangle and how they get on with it.
Offline Procomp
« Reply #5 on: 19 April 2012, 21:48 »
Hi
I have Eibech front and rear ARB fitted to my car, which does have the triangulated rear axle......think they all do?
Anyway, there is a centre damper which is held on by two bolts, if you undo and remove, you can attach it to the opposite side of the rear axle, as there are two holes there also.  It gets in the way otherwise so you are unable to fit the ARB flush with it the way.
It was a bit of fiddle I have to admit fitting the clamps, as I was lying under the car trying to push the clamps together whislt trying to tighten, but it should all go together.
I've got a build thread on my car, but it doesn't have too many pictures on the rear.  But if you search the 'How To' section  I think you may also find some info there.
Best of luck mate  :smiley:
Offline golfyste
  • Project track car
« Reply #6 on: 19 April 2012, 23:58 »
As daft as it sounds mate make sure the clamps are the write way round haha
When I did mine I didn't have then in exactly the right place and it seemed like they should fit bit wouldn't and just turns out I was bein daft  :laugh:
Offline colz1234
« Reply #7 on: 20 April 2012, 19:15 »
cool cheers for replies!
i will check out what procomp said tomorrow when i get a chance
my mechanic can be a bit of a numpty sometimes, but he is cheap
Offline colz1234
« Reply #8 on: 22 April 2012, 09:58 »
ive had a look, my jack doesnt go very high though so can only get a limited space to look
when you say the centre damper is held on by two bolts, do you mean the bit right in the middle of the axle, with 2 bolts about 2 inches or so away from eachother?
Offline Dave_IOW
« Reply #9 on: 22 April 2012, 13:08 »
Hi
This man is spot on, how I fixed mine  :afro:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
