Author Topic: Front camber  (Read 3521 times)
Offline liva2704
Re: Front camber
« Reply #10 on: 19 April 2012, 16:06 »
yeah i agree id like to hear more also.
Offline Ess_Three
Re: Front camber
« Reply #11 on: 19 April 2012, 17:00 »
I picked 2 Minutes out the hat because that is more than enough to see how much of a difference toe out can make to turn in. It's a start point to work from.
Much depends on driving style though. If you are smooth, you may need less, if you throw it in, you can probably use more.
I run 4 mins toe out per side and -1.85 degrees negative per side to get the front to do what I want...that's with a Torsen type LSD, despite many people suggesting you should run toe in with a LSD.
Quote
Castor makes a huge difference too but we can't change that without adjustable top mounts.
Well, you can get a bit my moving the subframe forward on the holes...or if you are brave, slotting the holes and moving it a few mm.
But ideally, you need something similar to this:
An additional 2.5 degrees of castor per side by loosening 4 bolts  :grin:
..but gaining motorcycles.
Offline liva2704
Re: Front camber
« Reply #12 on: 19 April 2012, 17:06 »
Cool im in the process of purchasing a camber gauge from fleabay so will hopefully be able to give it a go at the weekend.
Offline Dogbot
Re: Front camber
« Reply #13 on: 19 April 2012, 17:07 »
make sure the car is completely level when using one of the magnetic types dude  :wink:
Offline liva2704
Re: Front camber
« Reply #14 on: 19 April 2012, 17:14 »
Yeah thanks i gathered that might have to steal neighbours drive as mines on a bloody slope. :sad:
