Author Topic: Do you think these top mounts need doing?  (Read 4978 times)
Offline Sam
  • Sam I am
Re: Do you think these top mounts need doing?
« Reply #10 on: 17 April 2012, 09:14 »
So why wouldnt you do the cracked top mounts if your restoring it?  :laugh: Also, how are you working with the springs? Are you using compressors of just been ghetto? Just remember jay, dont put your finger where you wouldn't put your todger.
Offline clipperjay
« Reply #11 on: 17 April 2012, 12:10 »
The top mounts are loose on the rallye ones so just need to take off the locking nut and the other bolts bellow should hold the spring in place without loosing my fingers? :undecided:
Offline Diamond Hell
  • Opinions я Us
« Reply #12 on: 17 April 2012, 14:39 »
Get some Golf3 GTI mounts in there.  Grab a whole set up off a scrapper, that way you'll know how they assemble, too.
One of the things it's worth robbing off a Golf3.
Offline clipperjay
« Reply #13 on: 17 April 2012, 14:48 »
I would have DH and did along time ago, but I was thinking the Rallye ones are solid and new so just saving where I can mate!
Underlay carpet is another fav I steal off them better than the MK2 moldy ones you usually find  :grin:
Offline devilscaff
  • allways up for alaugh
« Reply #14 on: 17 April 2012, 18:56 »
you guys seem to really know your stuff,I have a low rumble noise and slight knocking from the front left could it be the same as your showng the shock mount cracked or worn?
Offline clipperjay
« Reply #15 on: 17 April 2012, 19:12 »
Low rumble does it get louder when you drive faster?
If it does it might be ball joint or wheel bearings?
Top mounts are more noticable going over pot holes and rough roads where the spring keeps hitting the top.
Problems with top mounts its only noticable if weights on them, but the ball joints and wheel bearings you can check with just spinning the wheel and listening.
Ball joints wiggle and see if there is play in them (they will move small amounts but not enough to feel like a space or metal hitting metal)
Offline devilscaff
« Reply #16 on: 17 April 2012, 19:23 »
sounds more like top mounts bearings were checked short while ago,also on full lock reversing sometimes here a big boing noise and your right pot holes do make it sound worse
Offline speedycoolboy
« Reply #17 on: 17 April 2012, 20:30 »
How do you actually change the top mounts? I'm new to all of this
Is it in the Haynes manual?
Thanks
Offline clipperjay
« Reply #18 on: 17 April 2012, 20:48 »
Need two tools and big balls  :lipsrsealed:
slotted nut removal tool 10.5mm usually
Compression Spring clamps
Offline JC
  • Back in the North.
« Reply #19 on: 17 April 2012, 21:25 »
O really  :huh:
 :lipsrsealed:
 :shocked:
 :laugh:
