Author Topic: Do you think these top mounts need doing?  (Read 4977 times)
Offline clipperjay
Re: Do you think these top mounts need doing?
« Reply #20 on: 17 April 2012, 21:41 »
Many moons ago I saw a lad same age I was 18 loose two fingers right in front of me!  :sick:
I don't do springs and mounts anymore after that even though with the right tools I might give it ago!
FK it I would rather pay for someone to change them for me its a phobia  :shocked:
Offline JC
  • Back in the North.
« Reply #21 on: 17 April 2012, 21:44 »
Yep, they can be killers. i seem some  :shocked: sights,
I got the clamps, and will happily whip springs off.
I owned 3 corsas and my daughters had one, spring changes were common  :lipsrsealed:
Offline clipperjay
« Reply #22 on: 17 April 2012, 21:49 »
Its wierd Chuff coilovers I have no problem with wound up tight and secure but stock springs it scares me mate never got over the finger accident!  :lipsrsealed:
Ebay got spring compressors and slotted sockets all the tools I've never wanted to own  :embarassed:
Offline JC
« Reply #23 on: 17 April 2012, 21:59 »
having worked on wheels tyres and suspension units on
for a decade plus, I can do mk2 golf units easily enough  :grin:
Offline clipperjay
« Reply #24 on: 17 April 2012, 22:04 »
Bloody hell no wonder a MK2 is a breeze for you  :grin:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #25 on: 17 April 2012, 23:14 »
The very first day I started work (Piss off Chuff) a mechanic had removed a coil spring from a Renault, and put it in the boot of the car for whatever reason. The spring was still very much under full compression! while in the boot, the spring snapped, and tore a hole straight through the rear 1/4 panel, flew across the workshop out of the building via a reinforced glass window, never to be seen again! Over the years have seen countless incidents, usually with poorly designed kit that slips.. we now have a floor mounted hydraulic compressor, that seems to do the job safely.
Thom
Offline clipperjay
« Reply #26 on: 18 April 2012, 00:28 »
You inspire me to not do the mounts Thom  :grin:
I've seen people use air guns to wind off the nuts insane they use the car wheel to stop the kick back  :lipsrsealed:
The only other way I've seen a cocked job was jacking the whole hub up then undo the nut that was dangerous not the jack end the top mount end  :lipsrsealed:
Offline Sam
  • Sam I am
« Reply #27 on: 18 April 2012, 00:30 »
This made me run, I was 17 and my mate was helping me put coilovers on my van. He said he had used compressors before so I left him to it and it ended up like this....
Offline JC
« Reply #28 on: 18 April 2012, 07:49 »
Thom
didnt know renault had been created by then  :huh:
 :kiss:
Offline clipperjay
« Reply #29 on: 18 April 2012, 10:41 »
guessing he didnt torque both sides up evenly  :shocked:
I'm going to a mate he has a hydrolic compressor and he said we will sort it out in ten minutes for ya!
Only problem is the dam slotted nut which is called a threaded bush nut or threaded sleeve insert
Both VAG part numbers match size and pitch (M14 x1.5 pitch)
811412965   = 5.50 plus VAT EACH  :shocked:
305412365A = 74P back order EACH  :lipsrsealed:
Anyone know the difference between the two prices?
