Author Topic: started stripping my engine today and this is what i found  (Read 2375 times)
Offline off_the_cuff
any 1 got any ideas as to where these plastic bits are from? thery throughout my engine and blocking flow of oil somewhere :S
Offline xAntiVenxm
Re: started stripping my engine today and this is what i found
« Reply #1 on: 16 April 2012, 17:50 »
are they definately plastic? could be bits of old rocker gasket? on one of my cars i went to take off the rocker cover, and the old gasket was still the original manufacturer one, 14 years of age, and was basically like fossilised wood rather than cork gasket! crumbled into a million little hard bits that i had to scrape out from around the rockers all through the inside, and after rinsing with engine flush for 15 mins, more of it came out the bottom, and had clogged the oil filter.
your blockage may well be the oil filter, when was it last changed?
if those bits are circulating through your engine oil system, they will get caught by the filter, and if there was enough of it, the oil filter's flow would be severely reduced
Offline mrsaunders
« Reply #2 on: 16 April 2012, 17:57 »
might be to do with the sump
« Reply #3 on: 16 April 2012, 18:08 »
definetely plastic, the gasket is still there and in 1 piece, so should i drain the oil and check the filter?
i havent took anymore of the engine off yet as i dont want to go down any further than neccessary lol
should i take the sump off 2 for a check?
Offline mrsaunders
« Reply #4 on: 16 April 2012, 18:15 »
yeah i would looks like sump baffle but cant be sure
Offline CJA321
« Reply #5 on: 16 April 2012, 18:46 »
Id take the sump off. Have seen this before and was broken up sump baffle and was blocking the oil pick up when oil pressure increased.
« Reply #6 on: 16 April 2012, 18:51 »
i'm taking the sump off now, do i just clean the bits outs, replace the baffle and oil and it should be fine?
« Reply #7 on: 16 April 2012, 21:29 »
Yes, those bits may also have come from the cam cover plate, maybe it brok in the past and they did not clear it out.
Offline xAntiVenxm
« Reply #8 on: 16 April 2012, 22:16 »
make sure you change oil filter too :) just in case you forget lol
Offline Khare
  • The bear that khares
« Reply #9 on: 17 April 2012, 08:51 »
Second. Could be baffle or cam cover plate.
Drain oil, take sump off, clean the oil pick up, new sump gasket and sump back on, clean any bits up top, new cam cover gasket and change the oil filter and stick some new oil in there.
