Author Topic: Indicators not indicating.  (Read 2622 times)
Offline Dave_IOW
« on: 16 April 2012, 17:21 »
When flicking the stalk up or down, they indicator bulb illuminates on dash and stays on.
The indicators themselves, front, side and rear, do nothing.
Would it be a fuse if they bulb on dash is coming on?   :undecided:
Sure this is an easy one for you very knowledgeable chaps!
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Sam
  • Sam I am
Re: Indicators not indicating.
« Reply #1 on: 16 April 2012, 17:41 »
Put your hazzards on, run around the car 4 times clockwise shouting 'flashyflashyflashy' repeatedly. Then run around once anticlockwise shouting 'yhsalf' twice.
Failing this, check the 10amp indicator fuse then check the relay.
Offline mk2bal
« Reply #2 on: 16 April 2012, 18:20 »
As above worked for me, the run around the car bit - always a winner. If it doesn't work for your car (its model specific) then cover your eyes, and wish for them to work. When you uncover your eyes and try it I guarantee you they will!!
Offline Dave_IOW
« Reply #3 on: 16 April 2012, 21:55 »
Ahh thank you for the replies, for a moment then I thought I was actually going to have to use a spanner/screwdriver..
I will wait till midday tomorrow to do this, which should provide the biggest audience, I'm sure the Golf won't want to be shown up infront of too bigger crowd.
Offline Dave_IOW
« Reply #4 on: 17 April 2012, 08:33 »
Got in it this morning and everything was back to normal...
Self fixing problems are my favourite sort.
Offline Sam
  • Sam I am
« Reply #5 on: 17 April 2012, 09:05 »
Sounds like the relay got jammed to me, would look asap. Im not sure if their is more that one and as for numers.... no idea, I cant even figure out my own relay numbers haha.
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 17 April 2012, 11:22 »
There's probably a spare to try in the fuseboard from the Cordoba if it does it again.
Offline Dave_IOW
« Reply #7 on: 17 April 2012, 17:30 »
Sooner than you would know, its playing up on the way home from work, and fine on the way.
The complete opposite to the driver.
Offline cняis
« Reply #8 on: 21 April 2012, 21:43 »
Push the flasher relay in properly...
If you dont know which one that is, push them all in harder  :evil:
Offline klapwijk
« Reply #9 on: 21 April 2012, 22:24 »
I've had this same problem, turned out to be a faulty hazard relay. Simple fix!
