Author Topic: VW repair wire connector Q  (Read 3758 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
« on: 15 April 2012, 12:07 »
oks can you buy the connectors which are on the end of the VW repair wires?
if so what are they called and what spec are they size etc
Many Thanks
Mikei
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline clipperjay
Re: VW repair wire connector Q
« Reply #1 on: 15 April 2012, 12:33 »
You can get them from VAG, but the ones I used where loose and not that great this place is good for aftermarket but ring them and send them an email showing what you need!
Mate-N-Lock connectors.
http://www.vehicle-wiring-products.eu/VWP-onlinestore/connectors/multiconnectors.php
Offline godsANGER
« Reply #2 on: 16 April 2012, 10:41 »
thanks matei,  :cool:
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 17 April 2012, 15:10 »
I checked this last week.
You CANNOT buy loose connectors from VW  - they only provide the 'repair' wires with connectors on them.
DannyP suggests shopping here for them, but I haven't had a chance to check this out:
http://www.polevolt.co.uk/
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #4 on: 17 April 2012, 16:37 »
Looks a good site just bookmarked it  :cool:
is the ones your after near bottom of this page?...
http://www.polevolt.co.uk/acatalog/Timer_Connectors.html
Offline tshirt2k
  • Been there...Done that...
« Reply #5 on: 17 April 2012, 16:47 »
In Etka. You get the part number for the Connector and the associated repair wires/pins will come up for it. You need to know thickness of wire required. usually in 0.5, 1,0 etc.
You will also need seals to go with it. They are the rubber bits that slide over the wire at the back that keeps moisture out.
Mk3 ABF 16VT Megasquirt V3
Offline godsANGER
« Reply #6 on: 22 April 2012, 15:27 »
think there connectors here are the ones i need [not the plug]
http://www.polevolt.co.uk/acatalog/info_1928404016.html
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #7 on: 25 April 2012, 00:00 »
This is handy.
Offline clipperjay
« Reply #9 on: 25 April 2012, 10:01 »
I bought the repair kit and the housing plug for the pins is shocking quality it was loose and they never sat properly into the recesses. Hence I use the lock types much more secure!
If you look at how they slide and grip thats the issues with them push in types and lock are much better! :wink:
