Author Topic: decoding used ecu who does it??  (Read 914 times)
Offline shaft69
« on: 15 April 2012, 07:23 »
Going to buy used ecu is dealer only one who can decode it so work on my car?? Anyone know?? Thanks.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline richw911
Re: decoding used ecu who does it??
« Reply #1 on: 15 April 2012, 10:43 »
Try ukmkivs there are a lot of people on there  :smiley:
Offline littco
« Reply #2 on: 15 April 2012, 13:55 »
Which car is it for and engine code. I may be able to help.
Offline shaft69
« Reply #3 on: 15 April 2012, 18:46 »
AUM mate.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline old_n07
« Reply #4 on: 15 April 2012, 20:19 »
If you can find someone local with Vag K+ Commander, you can fit the new ECU to the car then read the SKC from it using the software, once you have that it can be coded in with VCDS :afro:
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
