Author Topic: Components into a mk4 golf  (Read 4756 times)
Offline Mr_Orange
« on: 13 April 2012, 18:47 »
Hi,
Got a MK4 Golf, with Gamma 8 speaker set up.
I've upgraded the headunit to a Kenwood DPX503U.  Sounds great on the standard speakers, but as soon as I really crank it up or twiddle with the bass settings it all goes a bit waffly.  I've never been keen on fading back to rear speakers, so its set 99% to front.
I'm interested in fitting some components up front, so got a couple of questions....
Can component tweeters be shoe-horned into the existing speaker locations (at wing mirror)?
I know I'll need some adaptors for the door speakers, what's the best size speaker to go for, 16.5cm or 17cm?
Also what's the craic with speaker impedance?  The head unit states 4-8 ohm, is less more or more less when selecting speakers?
Build thread clicky
Offline Mr_Orange
Re: Components into a mk4 golf
« Reply #1 on: 14 April 2012, 08:42 »
Little bump.  Need some guidance here please  :smiley:
Build thread clicky
Offline pickles
  • Next!!!
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Offline Mr_Orange
« Reply #3 on: 16 April 2012, 18:58 »
Thanks mate, seen that, was after some further info.
Whats the deal with impedence?  I see most speakers are 4ohm.  Head unit it rated 4 to 8 ohm, is less preferable?
Build thread clicky
Offline T_J_G
« Reply #4 on: 16 April 2012, 19:18 »
4 Ohm's should be fine. 4 Ohms will draw more on the amplifier resulting in a ''better'' sound.
Offline stuartb3502
« Reply #5 on: 19 May 2012, 20:44 »
You just need to match speaker and head unit/amp. Impedances.  Lower impedance will draw more power from the amp. if the amp. can manage it.  Lower impedance needs better ampoification to maintain control.  Probably easiest to stick with 4 ohms unless you know what youre up to.
S.
2010 GTD.  RNS510 and Bluetooth fitted.  Hertz Hsk165xls, Audison Bt ten D, Hertz Hdp 4, Rockford Fosgate mono amp. Hertz 12" sub.  VCDS HEX+CAN available Camberley
Golf TDi 130 (Alpine head unit/iPod with Alpine KTP445 in-dash amp. behind glovebox).  Mission components front, OEM rears.  Kenwood 10" sub and Rockford Fosgate amp in removable box in the boot.
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
« Reply #6 on: 19 May 2012, 21:45 »
How about Rainbow IQ line or Eton's those are both direct fit  :cool:
