Author Topic: Mk2 1.8t conversion HEEEELLLLPPPP! please  (Read 14862 times)
Offline stealth_gti
« on: 13 April 2012, 11:59 »
I no this may of been covered a million and one times but everywhere i look im seeing different answers!
Could someone please just tell me in a simple answer which engine/gearbox mounts i need to use to drop my 1.8t agu into my mk2 golf but i am keeping my mk4 box.
Any help is worth beer tokens at spring gti fest if anyones going
cheers Scott
2** Bhp, 2** Lb/ft , R-Tech map, FMIC, Forge CL007P, Powerflow Cat-back, 18" Tsw pace, Eibach -40mm springs, Pipercross induction kit, vr6 Clutch g60 flywheel
Offline lemski
  • 16v
Re: Mk2 1.8t conversion HEEEELLLLPPPP! please
« Reply #1 on: 15 April 2012, 11:00 »
Pm'd
Offline danny_p
« Reply #2 on: 15 April 2012, 20:45 »
box dangling mount needs changing there are aftermarket arms avalible off the shelf
all the VW's have gone bar 1.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #3 on: 15 April 2012, 20:48 »
wide track it and fit MK3 subframe, then use the mk3 16v mounts  :wink:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline danny_p
« Reply #4 on: 15 April 2012, 21:00 »
slaps self i was thinking about 6 speed boxes for some reason
Offline Diamond Hell
  • Opinions я Us
« Reply #5 on: 16 April 2012, 15:01 »
There would be no need to put Golf3 trash like a complete subframe under it.
Even with the wide-track conversion you don't need to install a Golf3 subframe.
Brad as ever over-reaching himself with his interweb nolidge.
The most simple thing to do would be to use G60 mount at the back, on your current subframe, with a 1.3 (solid rubber) gearbox mount and a GTI-type mount at the front.  If you're using a cable-change gearbox you will need the correct flywheel, tinware and (importantly) the front mount bracket, plus driver's side driveshaft to suit the width of track you're using.
I would also supplement this with a pendulum mount to the gearbox to keep the movement down on the set up.
Offline mk2bal
« Reply #6 on: 16 April 2012, 18:28 »
What's a pendulum mount?
  • Opinions я Us
« Reply #7 on: 16 April 2012, 23:36 »
Has bracket on the chassis leg and comes down to the gearbox from above, to stabilise it.
Offline Dave-iow
« Reply #8 on: 13 November 2012, 08:41 »
Sorry to bump this back to the top, but.
Can we clarify which part and even part nunbers are needed.
I understand the G60 rea, Gti front and 1.3 gearbox mounts. But which bracket is need to run a cable clutch conversion ?
I know I will need the actuator (02b 141 708A) is the correct braket 357199356 ?
  • Opinions я Us
« Reply #9 on: 13 November 2012, 10:28 »
I think there's at least one actuator lying about in the barn.
The part I'm not sure we have is the clutch cable tensioner, as outlined:
Tensioning bracket to hold the end of the cable outer - described as a 'support' in ETKA: 357199356 - this was only ever fitted to early LHD 35i Passats
Which is the part you've highlighted, which you might need.  Let's take stock tonight.
That post above is from this post which outlines what you need for a cable-change cable-clutch set up:
http://www.golfgtiforum.co.uk/index.php?topic=88880.msg730322#msg730322
