Author Topic: Improving brakes on a Mk2  (Read 1336 times)
Offline jettaTx
  • Mk1 16v + Mk2 G60 + 309 Goodwood Mi16 + Jetta 16v!
« on: 02 June 2005, 09:29 »
I NEED TO GET MY BRAKES TO WORK A LITTLE BETTER ON MY MK2 GOLF
I am getting G60 Front set up i already have braided hoses but im looking for a Set up on the rear thats better than Mk2 ones What would ppl advise Mk3 or poss do Mk 4 fit ??? Also what parts will i need??? Mk2 discs??? Thanks
Offline Rain
  • forum irregular
Re: Improving brakes on a Mk2
« Reply #1 on: 02 June 2005, 19:56 »
G60 all round would increase it dramatically if its the standard 238mm setup. im not to sure about what you need but def the calipers and discs .
http://www.golfgtiforum.co.uk/index.php?topic=11158.0
read that thread from the mk2 section might be of some help to you
Offline animaniac
« Reply #2 on: 05 June 2005, 01:33 »
getting some good brake fluid will help...
and also using really good brake pads..... my mk 2 i got hold of the textar pads made by tmd friction http://www.textar.com/index.jsp
which make the sachs clutches! and also PAGID, MINTEX, DON, COBREQ and COSID
they gave a really good feel to the pedal and stopped good... i really liked the pads..
Offline Gambit
« Reply #3 on: 08 June 2005, 11:52 »
the rears do so little to the braking force that it wont make any difference at all. only reason people run mk3 & 4 calipers is so that the handbrake mech's dont seize
280mm G60 fronts with decent disks n pad
vr6 master cylinder
braided hoses all round
you'll stop on a 5p
