Author Topic: Removing front discs quick check  (Read 1968 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 01 June 2005, 19:59 »
Ok, i have the car ready to remove the front disc's is it the two bolts on the brake carrier i have to remove to get the disc off? I did try and remove them but i almost broke my arm! any tips on this?
also, are these the  two bolts that have to be renew as they are self locking aswell as the brake calliper bolts?
Offline AudiA8Quattro
Re: Removing front discs quick check
« Reply #1 on: 01 June 2005, 20:07 »
Depends on model.
If you have 256mm brakes which are fitted to later 16v's, you will need to remove the carrier.
I think this is what you have fitted to yours. The 2 bolts are 17mm and are NOT self locking type, but are very tight.
In all honesty you may need some pretty beefy tools to get the bolts out, depending on how long they have been on the car. This is because the bolts tips actually stick out the other side off carrier, so corrode like f**k. Might be worth checking this.
Hope that helps.
Offline Deefadog
« Reply #2 on: 01 June 2005, 20:36 »
Yep that the ones256mm and the carrier does have to come off, just need confirmation! I have soaked the two bolts all day in dw40 and if that will not budge them i have a blow tourch on stand by :)
So i can re-used thes bolts?
« Reply #3 on: 01 June 2005, 21:25 »
You can re-use the bolts as long as you don't f**k them getting them off  :laugh:
You need to spray WD40 on the end tips of the thread, look behind the disc, you will see them poking out  :laugh:
Offline Deefadog
« Reply #4 on: 01 June 2005, 22:03 »
Cheers mate, yeah i seen them poking out, well soaked :)
Will give it a go in the morning
« Reply #5 on: 01 June 2005, 22:07 »
Get a decent size breaker bar on it, otherwise it won't be going anywhere  :laugh:
Offline Deefadog
« Reply #6 on: 01 June 2005, 22:11 »
What's a breaker bar?
« Reply #7 on: 01 June 2005, 22:44 »
Just like a long bar with a head on it, basically like a rachet with a solid head instead for the socket.
Halfords sell them.
Don't bother doing the job unless you are equipped, otherwise you will just spend the whole day swearing  :laugh:
Offline Deefadog
« Reply #8 on: 01 June 2005, 22:50 »
Now Mr haynes never said i needed one! now why does that does not suprise me :)
I have a thick pipe which fits over my long handed socket rench, i'll try that first should do the job, i always have my blow tourch! has worked wonders in the past :)
Offline Deefadog
« Reply #9 on: 02 June 2005, 19:45 »
Stupid thing, nothing budged it :) Swear, swear, swear!!!!  I gave up, the disc's are not that bad, i'll have them changed by my mechanic next time i need something doing to the car!
