Author Topic: throttle body /maf sensor/alarm/immobiliser  (Read 2759 times)
Offline gedbedhead
« on: 12 April 2012, 16:38 »
cleaned throttle body and maf sensor today,battery was disconected as i was also removing steering wheel airbag etc anyway on startup idle is now at 1400 according to manual it says ecu has to relearn is that correct . i checked for air leaks seems ok runs smooth not lumpy just high idle any thoughts anybody thanks ged.
just read a previous post about re setting throttl sensor disconnect battery for a few hours re connect turn on ignition for 30 seconds turn off then start should be ok. will try that. should have read old threads first sorry guys will catch on eventually.
« Last Edit: 13 April 2012, 11:48 by gedbedhead »
Offline tweed
Re: throttle body /maf sensor
« Reply #1 on: 12 April 2012, 16:45 »
Put all vacuum pipes on? Could be sucking in air after the throttle body butterfly.
Offline gedbedhead
« Reply #2 on: 12 April 2012, 16:54 »
all vac pipes are ok checked for leaks at joint between tb and inlet chamber seems ok,forgot to mention did remove butterfly to give proper clean theres only two ways it can go on because of the locating indents,there is a slight gap on the bottom between butterfly and body but this was the same even if i swapped it round bout 1-2mm.
Offline search
« Reply #3 on: 12 April 2012, 16:56 »
i Clean my throttle body with out taking it off (lazy way lol)
can you not adjust the throttle cable? i had to do that on my 307 once to stay at 800rpm
Golf mk3 1.4 (sold)
Golf mk2 1.3 (sold)
Golf mk3 1.6
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #4 on: 12 April 2012, 16:57 »
Vag-com can put it into re-learn mode, but it will re-learn its self after a few miles, double check the throttle is fully rested on the stop just in case something is holding it open a bit.   But its quite normal for this to happen after its removed.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline tweed
« Reply #5 on: 12 April 2012, 17:11 »
Go for a b road blast and see how it is after that. 10 miles will be enough.
Offline gti gaz
« Reply #6 on: 12 April 2012, 22:45 »
What did you cleaf mad with?
 Any one in cornwall lets sort more meets!!!!
Offline gedbedhead
« Reply #7 on: 13 April 2012, 11:42 »
cleaned maf with brake cleaner.
Offline gedbedhead
Re: throttle body /maf sensor/fll closure alarm immobiliser
« Reply #8 on: 13 April 2012, 11:47 »
came across another problem when battery disconectted full closure alarm totally imobilised couldnt disarm,also happens when battery discharged,thought ide share this with everybody,reconnect battery with ignition in on position this then puts imobiliser into standby then immediately hold down arming button for ten seconds this resets system,everything okey dokey.
Offline boneybradley
  • Back in a Mk3...
Re: throttle body /maf sensor/alarm/immobiliser
« Reply #9 on: 13 April 2012, 12:18 »
Never clean the "electrical" maf with brake cleaner (which contains oil!).. try and use electrical cleaner as it's basically a wire element thats heated
disconnect the maf and see if it runs different (plus there is a specific way to reset the t/b properly....If i find it by using "search" I will post here  :wink:)
