Author Topic: throttle body /maf sensor/alarm/immobiliser  (Read 2758 times)
Offline forsh
Re: throttle body /maf sensor/alarm/immobiliser
« Reply #10 on: 14 April 2012, 16:47 »
Never clean the "electrical" maf with brake cleaner (which contains oil!).. try and use electrical cleaner as it's basically a wire element thats heated
disconnect the maf and see if it runs different (plus there is a specific way to reset the t/b properly....If i find it by using "search" I will post here  :wink:)
brake cleaner doesnt contain oil
thats why its brake cleaner
anyway the brake cleaner i use at work doesnt contain oil.but its industryal brake cleaner,and we get it in 60litre drums
Offline boneybradley
  • Back in a Mk3...
« Reply #11 on: 14 April 2012, 17:03 »
Ok it's not oil (it is similar to what's in wd40 though!!)..... it doesn't lube but its designed to protect and evaporate when heated (b.t.w I'm remembering my old carplan/tetrosyl days here!)
oh and it fk's maf's!!
Offline forsh
« Reply #12 on: 14 April 2012, 17:05 »
yes it defo fks mafs up no doubt about that brother  :smiley:,only thing you should use on mafs is air!,from a compressor,not a can!
Offline gti gaz
« Reply #13 on: 14 April 2012, 18:27 »
only ever use maf or elec connect cleaner on a maf i found out the hard way
 Any one in cornwall lets sort more meets!!!!
Offline gedbedhead
« Reply #14 on: 18 April 2012, 10:50 »
ust to let everybody know problem sorted.i recleaned maf with carb cleaner,for my own piece of mind ,i also resealed gasket on throttle body for the same reason,now heres the strange bit ,directly below throttle body there is an electrical connector going to that particular injector,it didnt seem to be fully clicked into position,all back together running at 850-900 at idle respose smoother and better pick up,think that connection might have been switching between on/off and other three compensating for it causing high idle?
Offline javalin
« Reply #15 on: 18 April 2012, 13:11 »
could be.  good spot.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
