Author Topic: vr6 conversion problem after problem  (Read 2216 times)
Offline mk1.8t
« on: 12 April 2012, 14:34 »
looking for some advice having major problems with my cabby that i have put a vr lump into.i had it all up and running fine last week,now it's dead will not even crank over.
cant even hear the fuel pump prime,all i get is the dash lights go to crank and nothing.
anything i could have missed,connections wise.
i have power to lights,windows etc just nothing engine wise
Offline sharki786
  • GOT BOOST??
Re: vr6 conversion problem after problem
« Reply #1 on: 12 April 2012, 15:55 »
the starter could be jammed. Have you tried bump starting it? Check your relays aswel. If you say the fuel pump dont prime then it might be the fuel pump relay.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Dmonday
« Reply #2 on: 12 April 2012, 18:15 »
Are you able to turn it over by hand?
Offline mk1.8t
« Reply #3 on: 12 April 2012, 21:55 »
yes engine turns by hand,got hold of a tester and checked there is no power to the ecu or engine???
Offline sharki786
  • GOT BOOST??
« Reply #4 on: 12 April 2012, 23:24 »
id say the ECU relay
*****MK4 GTI T*****
Offline mk1.8t
« Reply #5 on: 13 April 2012, 00:14 »
put in a brand new 109 relayand a fuel pump relay,made no difference :cry:.
what else could stop the power getting to the ecu and engine
Offline tweed
« Reply #6 on: 13 April 2012, 00:14 »
I would start by checking all wiring incase something is loose. You never know.
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 13 April 2012, 12:52 »
ignition switch maybe? i know mine is about ready to give up, plays up intermittently with similar symptoms but a little wiggle of the key and it'll fire up.
Offline Dan_GTi8v
« Reply #8 on: 13 April 2012, 15:15 »
could be wiring, maybe an earth has come loose. its usually the simple things :)
Offline boneybradley
  • Back in a Mk3...
« Reply #9 on: 13 April 2012, 15:22 »
could be lots of things..... but is this a post 1995 motor (as they need the key and transponder to match the ecu..or a bypass fitted)
