Author Topic: Wheel fitment  (Read 1389 times)
Offline Kus
Wheel fitment
« on: 11 April 2012, 20:27 »
I kno BMW wheels fit Vw's but do Vw's fit BM's?
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Wheel fitment
« Reply #1 on: 11 April 2012, 20:28 »
Huh? You can make anything fit anything with the correct adaptors!
Offline GJSEB79
Re: Wheel fitment
« Reply #2 on: 11 April 2012, 20:29 »
bmw wheels are not a direct fitment mate vw are 5x100 or 5x112 where as bmw are 5x120 i believe so the answer to your question is no unless you had some adaptors mate
Offline dom
  • Back in a Mk4
Re: Wheel fitment
« Reply #3 on: 11 April 2012, 20:31 »
As above, BMW wheels will only fit with adaptors
Re: Wheel fitment
« Reply #4 on: 11 April 2012, 21:46 »
Plus they tend to run low offsets which can cause problems with arch clearance etc.
Offline Kus
Re: Wheel fitment
« Reply #5 on: 11 April 2012, 21:49 »
You can't fit any alloys with adapters can you? For example pug wheels wouldn't fit a golf would they?
Offline Steve_PD
Re: Wheel fitment
« Reply #6 on: 11 April 2012, 22:01 »
You can get adapters to fit pretty much any PCD but as Wayne said its the offsets which will cause problems
Offline Kus
Re: Wheel fitment
« Reply #7 on: 11 April 2012, 22:14 »
Couldnt you use spacers to sort out the offset?
Offline scarr89
Re: Wheel fitment
« Reply #8 on: 11 April 2012, 22:26 »
When Wayne mentioned the low offset it means that the wheel will stick out further from the hub. So spacers would just stick out further! When using adaptors you have to talk into acc that they will probably be like 15mm or greater so would have to take that into account.
Offline Steve_PD
Re: Wheel fitment
« Reply #9 on: 11 April 2012, 22:27 »
If the offset is really low like ET20 (M3 wheels) then you add 20mm adapters/spacers which will give a final offset of ET0 which would mean your wheels would poke out of the arches by about 30mm or way too much
