Author Topic: What is the difference...  (Read 5416 times)
Offline scarr89
  • Mk4 Golf, DERV FTW!
« on: 10 April 2012, 11:42 »
between stage 1 maps and stage 2,3,4 etc....?
Am I correct in thinking that tuning a car is basically telling it to put more fuel in? So is a stage 2 just telling it put more fuel than a stage 1 map in?...and why do the higher stages cost more?  :rolleyes: :embarassed:
 :smiley:
Offline Yohan
Re: What is the difference...
« Reply #1 on: 10 April 2012, 11:44 »
Stages are more of a marketing thing to be honest, I wouldn't read too much in to it.
Offline Rhyso
« Reply #2 on: 10 April 2012, 12:05 »
In simple terms it tends to go like this
1 = Remap
2 = exhaust / intercooler / induction + remap
3 = bigger turbo / fuel pump etc + the above
At the end of the day the best way to look at it is what do YOU want from your car in terms of power and performance  :smiley:
Offline scarr89
« Reply #3 on: 10 April 2012, 12:14 »
1 = Remap
I kind of understand the 'order' in which to mod your car for power etc, I am just wondering what is the difference between a stage 1 and stage 3? As I said is it just about how much fuel you tell it to put? Or does a stage 2 map tell sensors to to ignore reading X & Y?
Offline Rhyso
« Reply #4 on: 10 April 2012, 12:27 »
1 = Remap
It's not solely down to throwing extra fuel in; much of if is about getting rid of the extra heat you produce and managing your exhaust gas temperatures to stop your engine melting  :nerd:
I'm sure someone with a greater understanding than me will explain it in more detail  :smiley:
« Last Edit: 10 April 2012, 12:30 by Rhyso »
Offline scarr89
« Reply #5 on: 10 April 2012, 13:26 »
^^ I get that bit, but like what does the tuner do on the laptop that makes the engine produce 50+ extra ponies?
I mean the tuner sat on the laptop I'm sure he doesn't have any bearing on flow of your incoming/outgoing gases, surely that is down to the mods on the car...
Offline shaft69
« Reply #6 on: 10 April 2012, 15:43 »
I know with my map from stage 1 to 2 gained 5bhp but torque was massive difference, also deleted post cat lambda sensor.  When I rang APR they said stage 2 map blends all add on mods together and post cat delete may see increase in power. Hence why stage 2 map is £40 if you have stage1 already, in states its free upgrade. With APR can adj map to fuel using via my cruise control stalk. Can turn map off, valet mode do if car goes I for serv won't rev over 3000rpm, 95 and 98 Ron settings.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline danny_p
« Reply #7 on: 21 April 2012, 23:55 »
the power comes from more boost and ignition timeing ( to a point )  but as rhyso said  youve got to stop it melting
all the VW's have gone bar 1.
Offline scarr89
« Reply #8 on: 22 April 2012, 16:36 »
Wouldn't that be down the mods that the owner has put on the car? How does the tuner control temperatures?
Offline topher
  • Administrator
  • fully functioning
« Reply #9 on: 22 April 2012, 16:41 »
hmm i think you need to do some research into how and why an engine creates its power and heat, before you can begin understand the answer to that question. Its really not just a case of turning things up a bit.
