Author Topic: 2006-2007 MK 5 Golf GTI (What to look out for)  (Read 4898 times)
Offline Gurrier
  • Towing the Line
« on: 09 April 2012, 19:48 »
Buying my 1st Golf GTI in a couple of months and have my heart set on DSG and leather seats  :drool:
Not sure if im buying local (Ireland) or gonna go to the UK to get one budget is about 9-9.5k Euros
Been doing some reading about servicing on these and sofar have figured out.
- 15,000km Oil change
- 60,000km DSG Fluid/Filter change
- 100,000km 1st Major service
Is there anything else i have missed that i should be looking out for (abit nervous as will more than likely be buying private and i hate to come across as a tyre kicker but i plan on keeping car for 3 years and looking after it to upgrade to a MKVI)
Thanks alot, if there is a sticky thread for these type of questions im sorry but i didn't see it.
MK1 Skoda Octavia 1.4 with various problems
Offline SRGTD
Re: 2006-2007 MK 5 Golf GTI (What to look out for)
« Reply #1 on: 09 April 2012, 21:24 »
Hi and welcome to the forum.
I'd also check the cambelt's been changed, depending on the age and mileage of any car that you're interested in. I'm not certain of the mileage that this needs changing - think it might be 60k miles (100k km?). However, the change interval is either the mileage limit or 4 years, whichever is reached first.
Some Mk5 Golfs have also suffered corrosion on the front wings; at the point where the wing is joined to the sill, and at the top of the wheel arch, above the wheel. The corrosion at the top of the wheel arch is caused by the plastic wheel arch liner rubbing the inside of the wheel arch flange. Inspect this area for missing or bubbling paint. Corrosion around the tailgate handle/badge is also not uncommon on early mk5's.
If a car's fitted with 18" Monza alloys, these are diamond cut with a lacquered finish. There's a limited number of firms that can refurbish these, so check carefully for kerbing and parking damage. Also check for whiteworm corrosion, which happens when water gets under the lacquer and the wheel surface has a cloudy white appearance. VW will replace wheels suffering from whiteworm under warranty if the car's less than 3 years old and the wheels don't have any other 'self inflicted' damage.
Good luck with finding the right car.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Gurrier
  • Towing the Line
« Reply #2 on: 09 April 2012, 21:32 »
Thanks alot, will post pics when i get her, might take a spin down to have a look at this example in afew days http://cars.donedeal.ie/for-sale/cars/3206329
Offline devilscaff
  • allways up for alaugh
« Reply #3 on: 10 April 2012, 18:08 »
Also ask about waterpump it should be changed with the timming belt as they are a weak spot because the have some plastic components they only cost about £50 and are expensive to do if not done at the same time
Offline Gurrier
  • Towing the Line
« Reply #4 on: 10 April 2012, 18:39 »
This is something i will be on the lookout for when buying, they should both be part of the 1st major service at 100,000km ?
Offline Philip James
« Reply #5 on: 10 April 2012, 19:11 »
Timing belt is to be replaced after 4 years or 60000 miles, whichever is reached first. Lots of threads on this.
Just found the perfect GTi...
« Reply #6 on: 10 April 2012, 19:13 »
It's not a requirement to have the water pump done at the same time, but makes absolute sense to do so.
Offline Gurrier
  • Towing the Line
« Reply #7 on: 10 April 2012, 19:17 »
Righto, i won't be touching anything w/o a FSH regardless, milage im looking at should be just after the first major service
Offline devilscaff
« Reply #8 on: 10 April 2012, 19:35 »
I'v had mine since october 07 from new and have enjoyed everyminute of having it,so much quicker than previous golf's I'v had not that bad on fuel.Only one small gripe, quite heavy on the tyres. So if you find one do check them the could cost up to £600 for all four corners for a top brand.
Offline ron bagley
« Reply #9 on: 11 April 2012, 10:03 »
Air con compressor's are a weak spot too. Many fail and cost close on a grand to be replaced unless you can wangle a "Goodwill gesture" to help!
