Author Topic: Mappers in the South West Wanted!  (Read 10204 times)
Offline Mr GTD
« on: 08 April 2012, 08:36 »
Hey all
Well after taking delivery of my new GTD on the 1st of march I'm finding I want more from it so my question is...
Is there any good mappers in the South West that can help me? either mobile or has a base....
Thanks
Steve
Offline shaft69
Re: Mappers in the South West Wanted!
« Reply #1 on: 08 April 2012, 08:57 »
Gwent vw Audi centre in Gwent do APR maps, run stage 2 map in mine I love it. Or nice drive over to r-tech top tuners if I say so myself.
« Last Edit: 08 April 2012, 09:00 by shaft69 »
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Mr GTD
« Reply #2 on: 08 April 2012, 09:08 »
Thanks, will take a look!
Offline Rhyso
« Reply #3 on: 08 April 2012, 09:11 »
If you want your GTD done then speak to The Doc; he runs a GTD  :wink:
Be warned, it involves opening up your ECU  :evil:
Offline Mr GTD
« Reply #4 on: 08 April 2012, 09:17 »
Will do, thanks :wink:
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #5 on: 08 April 2012, 09:36 »
Make sure you use a tuner who knows what they are doing with these new ecus, like Rhyso said they need opening up but also need to be extracted from there security mount which have shear bolt plus the ecu is glued and sealed.  Over on the mk5 gti froum there is a topic on damaged ecu from heavy handed removal.
I dont think APR do TDI maps?
IMHO I would go see Craig aka The Doc I know he has done many many of the anit tune ecus and has a nice clean method of getting the ecu out and open, plus will fit new shear bolts.
If your shopping around just make sure one of the questions you ask the tuner is what method they use to remove the ecu, give Craig a call first and he will explain the whole process to you.
 01455 617233
Offline Mr GTD
« Reply #6 on: 08 April 2012, 10:12 »
Thanks R-Tech, yeah I don't just want any cowboy playing with my engine and if I'm honest I do want Craig to do it as I know he knows what he's doing, I think the trip up to him will be well worth it esp the drive home :grin:
I know at the min he is busy with in house stuff at the min so will contact him when they re-open :wink:
Offline Adam
« Reply #7 on: 09 April 2012, 12:27 »
I've driven from Bournemouth to Craig's on a few occasions. Nice drive.
Down Hill From Here.
Offline JC
  • Back in the North.
« Reply #8 on: 09 April 2012, 12:33 »
espeically on the way home  :laugh:
Offline Adam
« Reply #9 on: 09 April 2012, 13:45 »
Not sure on the way home. I'm usually smiling like a Cheshire cat or the lovely countryside views are a blur  :undecided:
