Author Topic: Shallow sump 1.8T  (Read 5986 times)
Offline travisreeve
Shallow sump 1.8T
« on: 04 April 2012, 20:32 »
Guys... I NEED to put a shallow sump on my engine ( 1.8 20v turbo ) whats involved with doing this
Thanks
Re: Shallow sump 1.8T
« Reply #1 on: 04 April 2012, 20:35 »
Speak to Brad (kells) as he has looked into this, they are available but you run less oil which has mixed views on a turbo engine.
Offline mcgee9t2
« Reply #2 on: 04 April 2012, 20:55 »
i wouldnt run one as said the engines contain that amount of oil for a reason, if i was going to run one ide be doing oil services every 4-5k atleast
involved its just a case of buying the new sump and replacing, ide replace the pick up pipe while you have sump off.
some mk4s (think its only 2 out of the 3 mk4 engine codes but could be wrong) have a sensor on the sump i belive?
Offline murraymint
« Reply #3 on: 04 April 2012, 21:09 »
Raise the engine Insted?...
josh
Offline mcgee9t2
« Reply #4 on: 04 April 2012, 21:19 »
get stance+?
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #5 on: 04 April 2012, 21:20 »
had mine strengthened and its since been tested (numerous times) and for the people who didn't think the mod would work, it has stood up to the abuse fine  :smiley:
was looking to make my own sump that will be approx 1" shallow but will still have the oil level sensor and also still hold full oil as per OEM
its a WIP at the mo tho
Raising engine not possible, not in my MK3 or in the MK1 we did
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline barrym381
« Reply #6 on: 04 April 2012, 21:22 »
what did you do to yours on my 3rd sump now in the mk4  :angry:
Offline mcgee9t2
« Reply #7 on: 04 April 2012, 21:25 »
yeah ide be interested into how you streingthend it?
quite tempted at getting a sump guard or buying the ones you can get with the bottom made out of steel or what ever metal it is you can get which is suposed to be harder
Offline F17BAD
« Reply #8 on: 04 April 2012, 21:26 »
its in my thread someplace mate
in a nutshell, had it plated up with 5mm steel.. had got major scuffs now tho, but still in 1 piece
Offline barrym381
« Reply #9 on: 04 April 2012, 21:27 »
will have a look thanks mate  :smiley:
