Author Topic: new key fob casing now remote locking dont work please help  (Read 1161 times)
Offline wolfie1981
just bought one of these http://www.ebay.co.uk/itm/130640536026?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
i changed all the internals over and the blade so i did not have to get a new key cut BUT!! now my remote locking wont work
i googled about it and its saying to use your second key to program it is this true???
i only have the one key !!!
any help would be great
Offline stfc_gti
Re: new key fob casing now remote locking dont work please help
« Reply #1 on: 03 April 2012, 15:14 »
i only have one key too :-) ive lasted almost 2 years without needing a 2nd *touch wood*
2002 1.8T GTI AUM, Standard (not for much longer)
Offline Lankylad78
  • 60% of the time I'm right EVERYTIME
« Reply #2 on: 03 April 2012, 15:18 »
I had problems with my only key after changing the batterys in it. Try locking with the key, then unlocking. Worked for me  :smiley:
Offline wolfie1981
« Reply #3 on: 03 April 2012, 15:31 »
still not working :cry:
Offline wolfie1981
« Reply #4 on: 03 April 2012, 16:55 »
could i get the blade i had with the new casing cut and put that in the ignition and tune it to the on position and program my key with the transponder in the door??
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
« Reply #5 on: 03 April 2012, 22:47 »
I havent read all this link but found this thread might be of help thanks..
http://www.golfgtiforum.co.uk/index.php?topic=111526.0
Golf Gti
Offline cullygti
« Reply #6 on: 03 April 2012, 22:56 »
thats what i do and works fine same key for 3 years apart from2 new blades  :laugh:
Offline mcgee9t2
« Reply #7 on: 03 April 2012, 23:00 »
did you swap everything over? make sure you didnt crack the immobliser chip (cant see it stopping locking working but never know)
in that case ide try recoding it, think its something along the lines of put one key in the ignition and lock the doors but im sure someone who knows for definate will be along shortly, in the mean time have a google, sure there will be something on vwvotex or ukmkivs or here
Offline rio_gti
« Reply #8 on: 03 April 2012, 23:17 »
I'm pressy sure you can do it with vag com or vag tacho
Edit: just checked it's doable with tacho
« Last Edit: 03 April 2012, 23:22 by rio_gti »
Offline wolfie1981
« Reply #9 on: 04 April 2012, 07:54 »
ive been told i need a second key to recode i.e one for the ignition & one for the door but i only have the one!!
dont know if i could get the blank blade that come with the new case cut and use that in the ignition and the recode mine in the door??
