Author Topic: Oil leak! :(  (Read 2371 times)
Offline rockmonkey69
Re: Oil leak! :(
« Reply #10 on: 02 April 2012, 13:13 »
Your supposed to let it sit for 4 hours before filling with oil and it helps to put a bit of silicone sealer on the crank cover.
Offline golfyste
  • Project track car
Re: Oil leak! :(
« Reply #11 on: 02 April 2012, 13:41 »
Hmmm ok may have to try that although I didn't think you had to remove the oil as it o lu comes into contact with it when the crankshaft is spinning as when I removed the seal no oil eacaped
Re: Oil leak! :(
« Reply #12 on: 02 April 2012, 14:15 »
That's odd I had a leaflet with mine which said to leave it dry for 4 hours, you might be right just install and fill then drive.
Offline golfyste
  • Project track car
Re: Oil leak! :(
« Reply #13 on: 02 April 2012, 14:17 »
Hmmm I dunno ha, just want it to start working so ican book my map!  :angry:
Re: Oil leak! :(
« Reply #14 on: 02 April 2012, 14:33 »
It is running! - albeit with a slight leak  :tongue: (I'm assuming it's only a small leak)
I always apply a bit of silicone sealant on the cover (front and back crankshaft covers) to help seal
Offline golfyste
  • Project track car
Re: Oil leak! :(
« Reply #15 on: 02 April 2012, 14:36 »
Well the pic on the first page was literally when I pulled up flicked it off got outside and looked underneath, so it's not tiny and don't think r tech want my oil all over their rollers  :laugh:
Offline golfyste
  • Project track car
Re: Oil leak! :( ......SORTED!
« Reply #16 on: 05 April 2012, 20:35 »
Finally after pain stakingly removing the timing belt 3 times and and still having a oil leak I finally got it sorted!
Found that the crank shaft oil seal hosing was worn  :huh: an wasn't dealin on the out side so had to buy a new one from tps. Got it all backtogether just now and hey presto no leak  :grin:
So think I will be ringin and booking my map with r tech tommorrow  :cool:
Will start a post and List all my performance mods later......shower time  :laugh:
Re: Oil leak! :(
« Reply #17 on: 06 April 2012, 21:40 »
Good result with sorting the leak :afro:
Offline golfyste
  • Project track car
Re: Oil leak! :(
« Reply #18 on: 06 April 2012, 22:29 »
Cheers mate happy now it's finally sorted.
Totally forgot about ringin r tech today tho so gonna ring them tommorrow  :laugh:
Offline daz veedub
  • Operation 1.8t bolf
Re: Oil leak! :(
« Reply #19 on: 06 April 2012, 22:37 »
nice 1 that u sorted it
