Author Topic: Best place for new gearbox and starter motor?  (Read 1776 times)
Offline jnufcuk
« on: 29 March 2012, 16:03 »
Just got car bk from garage after having thermostat fitted and to look at starter motor.
Car gets up to temperature alot quicker, mpg also improved so that's the good news :D
Bad news: he tried to clean and grease starter motor but it is on its way out so need to look at gettig a new one some time :(
Also gear box is on way out :( so need a reconditioned one? Best place and price?
It's for 2003 5 speed 1.8t (aum)
Thanks
Offline richw911
Re: Best place for new gearbox and starter motor?
« Reply #1 on: 29 March 2012, 16:17 »
Whats up with your gearbox?
Offline barrym381
« Reply #2 on: 29 March 2012, 16:36 »
had my agu box reconditioned start of 2009 for 195 as 1st an second gear were gone
Offline jnufcuk
« Reply #3 on: 29 March 2012, 17:07 »
Getting hard to get into gears, makes a crunching noise in some gears and u really have to force it into gears. Tried the linkage and other bits but suspects its something inside the box so was recommended to get a reconditioned one.
Offline richw911
« Reply #4 on: 29 March 2012, 17:23 »
Clutch is ok / new ?
Offline jnufcuk
« Reply #5 on: 29 March 2012, 17:49 »
He clutch seems fine. Not slipping or anything still strong biting point.
Offline brianpologti
« Reply #6 on: 29 March 2012, 19:07 »
You sure the clutch is ok , sounds like it's dragging
Offline navmk4gti
« Reply #7 on: 29 March 2012, 19:18 »
you tried changing gearbox fluid  :undecided:
Offline jnufcuk
« Reply #8 on: 29 March 2012, 19:33 »
I was losing gears a while back then did the gear linkage thingy and it was fine then it just became harder to change gears, having to force them in. Plus a clunking noise when changing gears.
No haven't changed fluid. Would that make any difference?
Offline navmk4gti
« Reply #9 on: 29 March 2012, 19:44 »
cheapest option and may do
