Author Topic: Best place for new gearbox and starter motor?  (Read 1775 times)
Offline jnufcuk
Re: Best place for new gearbox and starter motor?
« Reply #10 on: 29 March 2012, 19:51 »
I was losing gears a while back then did the gear linkage thingy and it was fine then it just became harder to change gears, having to force them in. Plus a clunking noise when changing gears.
No haven't changed fluid. Would that make any difference?
cheapest option and may do
Might try it then. Easy to do?
Offline brianpologti
« Reply #11 on: 29 March 2012, 20:00 »
Just don't use apsley Transmission ,  :sick:
If you need a good garage near you give me a shout , I know someone that I ve taken all my cars, top bloke
Also if your feeling like you want some scrap heap challage they mine be a 1.8t in Hemel scrap yard, it's on eBay at min with no takes ,
« Last Edit: 29 March 2012, 20:02 by brianpologti »
Offline navmk4gti
Offline jnufcuk
« Reply #13 on: 29 March 2012, 20:03 »
Been reading up doesn't look much harder than an oil change so should b able to do this :)
( I've got a garage that i use, thanks mate)
Offline jnufcuk
