Author Topic: Where has all my water gone???  (Read 4153 times)
Offline tweed
Re: Where has all my water gone???
« Reply #10 on: 29 March 2012, 13:29 »
Topping up with water is fine. Especially in this weather.
Offline AudiA8Quattro
« Reply #11 on: 29 March 2012, 13:36 »
Coolant also helps prevent corrosion.
However i would only put water in if it's all dissappearing, at least until i found the source of the leak!
Offline bob23
  • Hi, for those of you that don't know, I'm a tw@!
« Reply #12 on: 29 March 2012, 15:02 »
When I know where it all went I was planning on flushing the system, replacing the rad and using coolant, just to update gone to it today and there is no water in the bottle, haven't topped it up yet to see how much it has lost.
Current cars 1995 Golf gti colour concept 2.0 8v 156,000 miles. bmw 316 1.9 129,000. yeah, life's good! :rolleyes:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #13 on: 29 March 2012, 15:12 »
The water fairies have drunk it all.
Offline MK3 Menace
  • 98 GTI, big changes are coming...
« Reply #14 on: 29 March 2012, 15:35 »
Mine did the same as this and it was leaking out the side of the tank next to the wing. Where it bolts to the mount. Check all round the tank for leaks.
Offline VR6_Wherry
« Reply #15 on: 29 March 2012, 15:38 »
Mine is leaking too, I filled it up yesterday drove a bout 5 mins. Stopped with the engine running then drove round the block and when i came back there was a puddle where i was stopped. Need to source the leak also but at least i know it's not the head!
Offline bob23
« Reply #16 on: 29 March 2012, 15:40 »
Yeah... Sure :rolleyes:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #17 on: 29 March 2012, 17:39 »
Its leaking from the bottom right corner of your radiator i bet.... Take a look for wet patches with a tourch.   :wink:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline andy-gti84
  • lowanslow
« Reply #18 on: 29 March 2012, 20:06 »
got a 8v as well an mine is doing the same have to fill it ever 3 days. just got my self new water pump,thermst,-flang that sittn at front of block. going to get it all sorted next week.
Offline bob23
« Reply #19 on: 29 March 2012, 23:23 »
I'll have a look on my next day off, if that is all it is then I'm not bothered as I will be changing the rad anyway.
