Author Topic: forge actuator  (Read 2285 times)
Offline jonnyturbo
forge actuator
« on: 28 March 2012, 08:00 »
Been reading a few posts . Does the forge actuator bolt strait to the k03s VIA same mounting points ? Bloody wants to for 100 beans . I know Dave iow had a bit trouble that's all
Offline brianpologti
Re: forge actuator
« Reply #1 on: 28 March 2012, 09:00 »
I ve fitted two , one on my daily and one on the Anni, both had different brackets to each other,(forge actuator) and both wasn't a straight fit, but with a bit of drilling/modding they fitted,
Think they come with 3 to4 different brackets .
Forge do send out replacements for them,
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: forge actuator
« Reply #2 on: 28 March 2012, 19:39 »
blame Borg Warner, they're the ones that kept changing the positions on the holes lol
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: forge actuator
« Reply #3 on: 28 March 2012, 20:27 »
the one i fitted to my old k03s was a straight fit. Your old actuator comes off by undoing the 3 bolts that hold its bracket to the turbo and the 1 nut that holds it in place on the wastegate arm. then fitting is the forge one was the reverse of that. simples.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: forge actuator
« Reply #4 on: 28 March 2012, 21:51 »
Paul there are 3 different brackets I think, Chris had this problem when he fitted his. I got lucky like you though lol
Offline Hulmie
Re: forge actuator
« Reply #5 on: 28 March 2012, 22:01 »
yeh guess i did drop lucky then. I know the K03 bracket is different.
Jonny - Did you get the spring kit aswell? I used the red spring in my old one
Offline Dave_IOW
Re: forge actuator
« Reply #6 on: 28 March 2012, 22:55 »
Yes mate, i had problems as the bracket would not fit the KO3s it was going on, nor the KO3 i took off..
I drilled 2 holes into the standard bracket it hink (cheers Wes  :afro: and mounted it on the standard bracket..
I fear i will have to do the same again to the 001 although its not that much of a hardship tbh..
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Re: forge actuator
« Reply #7 on: 29 March 2012, 19:08 »
Make sure you get the right spring too ,
Offline jonnyturbo
Re: forge actuator
« Reply #8 on: 29 March 2012, 20:00 »
Yep got the yellow spring lol its all in hand
Re: forge actuator
« Reply #9 on: 29 March 2012, 20:05 »
A Tenner if you buy it separately ,
