Golf mk4
Wazzzer
polo top mounts fitted is this correct
Topic: polo top mounts fitted is this correct (Read 2217 times)
rench
Here all the time
24 March 2012, 22:12 »
anyone run polo top mounts? if so how much did they lower car by and do they work ok?
Last Edit: 30 March 2012, 19:40 by rench
http://www.golfgtiforum.co.uk/index.php?topic=228442.0
cullygti
Re: anyone run polo top mounts?
24 March 2012, 22:13 »
sure wazzer used these and iirc about 10mm mate
rench
Here all the time
24 March 2012, 22:18 »
they work fine no problems? im after a drop around 10mm anyway
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
24 March 2012, 22:29 »
I use supersport top mounts but basically give the same result
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
rench
Here all the time
24 March 2012, 22:34 »
found these
http://www.ebay.co.uk/itm/FK-10mm-Lowering-Springs-Caps-VW-Golf-Mk4-Mark-4-/330622768932?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item4cfaa71724&clk_rvr_id=326821230540&afsrc=1
which would you recomend them or polo top mounts they cost about the same
Wayne
Sir Postalot
24 March 2012, 23:53 »
Lowering Spring caps are a good idea, I have used them in the past all ok.
Last Edit: 25 March 2012, 20:41 by Wayne
jamie16v
Guest
Reply #6 on:
25 March 2012, 11:29 »
Quote from: Wayne on 24 March 2012, 23:53
Spring clamps are a good idea
brianpologti
Here all the time
Reply #7 on:
26 March 2012, 09:14 »
I am running them with standard Anni stuff, no problems . Think they only 30quid , I only put them on as my standard one were knackered
rench
Here all the time
Reply #8 on:
26 March 2012, 11:54 »
Do you have to change the tops ate just the bush?
rench
Here all the time
Re: polo top mounts fitted is this correct
Reply #9 on:
30 March 2012, 19:41 »
just fitted one of the polo top mounts does this look right, should there be a lip that comes through the strut?
Golf mk4
Wazzzer
