Author Topic: No power to my amp  (Read 3843 times)
Offline clancy
No power to my amp
« on: 23 March 2012, 14:39 »
Hi guys just put my sub in my mk3, I've had this is my 2 previous cars no problem. For some reason I'm now getting no power to the amp.
Checked the fuse on the power cable and the amp, there both fine, power cable I've tried connecting to all the positive terminals And nothing. Any ideas :s?
If it was the earth or rem installed wrong there would be a different colour light, but I have no light so it has to be the power cable Causing the issue.
MK3 GTI 16v
Offline dragonfly
Re: No power to my amp
« Reply #1 on: 23 March 2012, 16:21 »
Is it conencted to a clean earth?  The remote should go to the remote lead on the headunit.
"I've tried connecting to all the positive terminals"? The amp power should come direct from the battery.
« Last Edit: 23 March 2012, 16:23 by dragonfly »
Offline clancy
« Reply #2 on: 23 March 2012, 18:31 »
Not sure on the earth, but if the earth was bad I get a red light come on, got nothing ATM.
There are no free terminal things on the battery so I just put it on where other stuff connected, did the same on my last car and it worked. How can I get a clean contact to the battery?
MK3 GTI 16v
Offline dragonfly
« Reply #3 on: 23 March 2012, 20:52 »
Where is the earth connected at the moment?
Offline clancy
« Reply #4 on: 24 March 2012, 08:51 »
One of the rear seatbelt mounts, dOnt know if that's any good but it doesn't matter, like I said I'll just get a red light come on
How is your power cable connected to your battery ?
MK3 GTI 16v
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 24 March 2012, 10:32 »
Mine had a poor Earth and got no power whatsoever. Took me a while to figure it out but once sorted all works ok now.
Offline clancy
« Reply #6 on: 28 March 2012, 11:39 »
what you guys earthed off of ??
MK3 GTI 16v
Offline Len
« Reply #7 on: 28 March 2012, 12:13 »
I use the earthing point of the rear light clusters/central locking pump
www.sas.org.uk
www.the-ace.org.uk
Offline Deano2711
  • 1992 VR6
« Reply #8 on: 28 March 2012, 22:52 »
Rear seat belt bolt under the parcel shelf support. It did take me a couple of attempts to get a good enough earth though.
Offline mcgee9t2
« Reply #9 on: 29 March 2012, 17:50 »
mine too, however i sanded mine right down to bare metal, then a little further so my earthing is good
