Author Topic: Centre arm rest/console remove?  (Read 6452 times)
Offline mkviken
« on: 22 March 2012, 16:05 »
I've got a really annoying rattle inside the centre console unit at 3200rpm. It's so irritating but I'm certain it's coming from there as when I open the arm rest it's really loud.
Anyone know how to break the console down so I can find the rattle from inside? Cheers
Golf GTI 7.5 230 white silver
Offline Jimble
Re: Centre arm rest/console remove?
« Reply #1 on: 22 March 2012, 16:09 »
No idea how to pull it apart but could it be your MDI cable? Mine rattle/knocks from time to time.
Offline Sean465
« Reply #2 on: 22 March 2012, 16:26 »
are you sure your bottle opener is not still in there!?  :laugh:
Offline mkviken
« Reply #3 on: 22 March 2012, 19:53 »
i found the problem
took the arm rest console apart and test drove and the rattle was even louder but i couldn't pin point it.
took the handbrake roller blind trim off and the rattle was gone
only does it at around 3200rpm to about 4000rpm. really annoying loud buzzing
fixed it by packing out the piece with felt tape. what a pain in the arse to get the console back together as it was dark by the time i got it sorted!
test drove and rattle gone but can just hear other rattles instead... this one was really loud though so glad to get it fixed
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #4 on: 22 March 2012, 22:37 »
Wish mine rattled as quietly as yours  :grin:
I have read about this rattle elsewere.
Could you point me to a supply of felt tape as I plan on doing my doors in a couple of weeks time
Current Garage:
35+ years of GTI ownership.
Offline mkviken
« Reply #5 on: 22 March 2012, 23:04 »
no seriously this one is REALLY loud.
it must depend on temperature or something cos it comes and goes some days but its always at a certain RPM range so certain vibrations set it off.
if i open the arm rest it was so loud it almost drowned out engine noise.
i just go the felt tape off ebay. seems to have done the trick
did you take you B pillars off? is it just 1 screw under the airbag badge? I've got a rattle on both b pillars and boy front door cards which i need to sort with some tape too.
Username
« Reply #6 on: 23 March 2012, 19:04 »
Q to you guys who've developed rattles etc.
Have you been driving conservatively or been enjoying your car ?
C'mon be honest..
Offline Jimble
« Reply #7 on: 23 March 2012, 19:10 »
In my case it's a mixture of both but my main problem is the rediculous amount of speed humps in my area!! :angry:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #8 on: 23 March 2012, 19:12 »
Mines only done commuter miles
I just eased the trim up as shown in the vw tpi and fitted the tape as its the overlap of the two panels that sometimes rattled on mine.
« Last Edit: 23 March 2012, 19:16 by Snoopy »
Current Garage:
Offline mkviken
« Reply #9 on: 23 March 2012, 19:23 »
ok will give it a go.
the handbrake buzzing seems to be fixed now
just for the front doors and b pillars and a nightmare of a rattle in the passage footrest/seat area to sort now. the one in the centre of the dash is intermittent so can live with it
C'mon be honest..
shouldn't make a difference. how you drive it or the life it leads regarding interior rattles.
i only use my car for B-road blasts but it always immaculately clean, always garaged, fair weather use only, always warmed thoroughly before taking above 4000rpm and warmed down before i leave it.
and mine still rattles.
