Author Topic: Golf GT TDI 115 remap  (Read 3397 times)
Offline simpsonstarwars
  • Mk4 1.6 cosmic to gt tdi 115
« on: 22 March 2012, 12:07 »
hey :)   saved some money for a remap on my gt tdi 115 and im aware its a good idea to get a better clutch , just wondering what is the better one to get for this model ?
cheers :)
Offline Rhyso
Re: Golf GT TDI 115 remap
« Reply #1 on: 22 March 2012, 12:32 »
Depends how far you want to take the power.
Just the OEM clutch will be fine if you're only going for a stage 1 remap.  Anything past that then I'd go for an uprated Sachs clutch; be warned that they ain't cheap!
« Reply #2 on: 22 March 2012, 16:58 »
yeh would only be a stage 1 ,  thanks for the info ,
any recommendations for places to go i.e revo , jabba sport, and such?
Offline richw911
« Reply #3 on: 22 March 2012, 17:18 »
How about Kinetic tuning? See above your post  :laugh:
« Last Edit: 22 March 2012, 17:30 by richw911 »
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 22 March 2012, 22:37 »
check your ECU part# first. if it ends 019AM you won't be able to remap it via the obd port
« Reply #5 on: 22 March 2012, 22:55 »
where abouts is this code and is there a simple way to check ?
also what happens then in regard to remaping it?
cheers
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 22 March 2012, 22:58 »
simplest way is to plug in vagcom, less simple way is to remove the wipers/scuttle and whip the ecu out.
if its 019AM you could do a "chip out" remap or just replace the ecu with a later 019CJ which you can pick up for about 50 quid on ebay. you can map those by obd without issues.
Offline cullygti
« Reply #7 on: 22 March 2012, 23:01 »
your clutch dmf could be weak and a lot of ppl then go on to blame the map for them breaking down not working as they should etc the reality of it is that they are aleady weak to start with and the map just puts more strain on them making them weaker so in theoretical terms you should be prepared to change them or do it before the map hth  :smiley: and as above contact rhyso for a good map on a derv aka kinetic tuning sure he will point you in the right direction  :wink:
« Last Edit: 22 March 2012, 23:03 by cullygti »
« Reply #8 on: 22 March 2012, 23:04 »
nice one, cheers for the advice   :grin:
