Golf mk4
Wazzzer
Rear brakes
Topic: Rear brakes (Read 1460 times)
davemusic_123
Rear brakes
21 March 2012, 19:35 »
I was fitting some new rear brake pads, when I got a leak in one of the pipes. So I replaced that and then bled the whole brake system. So there's no air in there now. But when I turn on the ignition on I have no brakes at all?
gm8
Re: Rear brakes
21 March 2012, 19:48 »
did you replace the washers on the banjo fitting ? did you bleed whole system including master cylinder ? pressure bleed or 2 man method ?
scarr89
Mk4 Golf, DERV FTW!
Re: Rear brakes
21 March 2012, 19:54 »
A few people have had problems bleeding their brakes recently, so glad I didn't do mine
If there is air in the system could you not just 'bleed' the air out of the system until fluid comes out of all the nipples?
davemusic_123
Re: Rear brakes
21 March 2012, 20:01 »
I bled each caliper thats all. two man job
gm8
Re: Rear brakes
21 March 2012, 20:03 »
should really pressure bleed , 2 man job can filp seals in master cylinder. If there is no washers on the banjo fitting thats a prob !
JimBR
Re: Rear brakes
21 March 2012, 20:44 »
Bleed the 2 nipples on the master cylinder
davemusic_123
Re: Rear brakes
Reply #6 on:
22 March 2012, 07:54 »
I'm on that this morning nice one
golfyste
Project track car
Re: Rear brakes
Reply #7 on:
22 March 2012, 10:29 »
Remember that brake system work on diagonal opposites. As in the offside front is connected to the neat side rear and near side front is connected to offside rear. So if you loose fluid from one of the rear brakes it's not both rears you have to bleed.
R-tech custom remap - k04-001- 250bhp/311ftlb
"Project track car" has begun
davemusic_123
Re: Rear brakes
Reply #8 on:
23 March 2012, 09:29 »
Thanks that's good to know, well Ive bled the master cylinder and got some air out of there. But theres still air in there somewhere. I noticed I had a leak on my rear caliper hose, so that a job for this morning then more bleeding great fun
Wayne
Sir Postalot
Re: Rear brakes
Reply #9 on:
23 March 2012, 21:42 »
I believe they should be bleed with the engine running.
Golf mk4
Wazzzer
Rear brakes
