Author Topic: blown head gasket?  (Read 2958 times)
Offline devilscaff
  • allways up for alaugh
blown head gasket?
« on: 21 March 2012, 15:58 »
only had it three weeks done lots of bit to her after changing my gearbox oil yesterday decided to take to work.Having a bit of fun when a huge cloud of smoke came from the rear and temperature light came on. Pulled over and there was no water in the engine and radiator pipe had burst. Put as much water asposible to get it half mile to safty but was smoking  like a b!tch is  it head gasket gone?
Offline The Mighty Elvi
  • I'm better than you today.
Re: blown head gasket?
« Reply #1 on: 21 March 2012, 16:41 »
Had the pipe ruptured due to extreme pressure by the look of it. Or was the water loss just down to a split because of its age?
Fit a new pipe and fill it back up and run.  Then you'll see where the leaks are.
Offline devilscaff
« Reply #2 on: 21 March 2012, 17:08 »
try and get a new pipe then asap (miss her already)
glove
« Reply #3 on: 21 March 2012, 17:47 »
« Last Edit: 22 April 2012, 00:20 by glove »
Offline devilscaff
« Reply #4 on: 21 March 2012, 18:59 »
Spoke my machanic verbally, he says as the  smoke from the exhaust is more likely steam which means water has got in the engine so b#@?ocks headgasket gone!!!!thats gonna hurt
Offline Seanl
« Reply #5 on: 21 March 2012, 19:30 »
Depends what colour the smoke was. He's gonna say something like that, he wants your money! Is your oil filler cap creamy?
Offline devilscaff
« Reply #6 on: 21 March 2012, 20:05 »
no the oil looks fine, but I have noticed the car using a little bit of water and temperature gauge on the dash not working
Offline Seanl
« Reply #7 on: 21 March 2012, 21:07 »
Water leaking through a knackered sender............
As suggested on here mate, sort all your water leaks out before panicking about headgaskets. What colour was the smoke? As said, it could have been steam, but that could have been from the water splashing on the block and exhaust, but obviously with you travelling, you only saw it at the back. Only real way to confirm its not HG is a compression test, but don't flap yet!
Offline devilscaff
« Reply #8 on: 21 March 2012, 21:10 »
ok thanks for that should try and get hose replaced first then see what happens
glove
« Reply #9 on: 21 March 2012, 23:56 »
« Last Edit: 22 April 2012, 00:21 by glove »
