Author Topic: N249 questions  (Read 2004 times)
Offline AD1.8T
N249 questions
« on: 20 March 2012, 19:04 »
Just followed the guide on it all went well except i snapped a nipple off the n112 (good ole soldering iron and araldite) its now sorted
Couple of things
1. If it was faulty would it of put me down on power .... Cause i just took it out for a spirited drive and it spins up in second with no effort what so ever (its never done that before) it does feel alot more pokey and smooth now which is good
2. I now have a different noise coming from the 007p this time theres no pinched pipe lol its alot sharper and abit louder as i can now here it with the window down which i couldnt before its more of a ttssshh than a woosh noise so if you want more noise do it do it now !
3. Im replaceing the boost pipes with a forge kit when they arrive is there anything else that would cause a boost leak while im at it ?
Offline AD1.8T
Re: N249 questions
« Reply #1 on: 21 March 2012, 17:16 »
Annnnnnnyyyyyyybbbbbboooooooodddddddyyyyy ?
Offline Steve_PD
Re: N249 questions
« Reply #2 on: 21 March 2012, 17:32 »
A faulty N249 can give power loss and boost issues
http://wiki.ross-tech.com/wiki/index.php/17608/P1200/004608
Offline Dalo Harkin
Re: N249 questions
« Reply #3 on: 21 March 2012, 17:32 »
Are you trying to do the bypass?
Offline AD1.8T
Re: N249 questions
« Reply #4 on: 21 March 2012, 17:36 »
Offline Dalo Harkin
Re: N249 questions
« Reply #5 on: 22 March 2012, 08:20 »
Why aren't you getting rid of both, If you are doing the bypass?
Offline rio_gti
Re: N249 questions
« Reply #6 on: 22 March 2012, 08:38 »
think this is where i went wrong..... i only bypassed the n249 but i know i still got the other solinoid connected under the tray with vacuum connected to it.
should this one be bypassed too then so the vacumms go direct from manifold??  :undecided:
edit: as the guide on here doesnt bypass it!!
« Last Edit: 22 March 2012, 08:49 by rio_gti »
Offline AD1.8T
Re: N249 questions
« Reply #7 on: 22 March 2012, 08:51 »
Ive just copied the how to mate and he never done it on there something to do with the sai ..... The only thing i done different is that i didnt t into the fpr for the 007 i t'd into the other one
Offline rio_gti
Re: N249 questions
« Reply #8 on: 22 March 2012, 09:19 »
what hose did you use??
Offline AD1.8T
Re: N249 questions
« Reply #9 on: 22 March 2012, 12:53 »
3mm ebay jobby how come ?
