Author Topic: oil catch can install please help  (Read 8280 times)
Offline wolfie1981
« on: 19 March 2012, 17:20 »
this week i plan on installing a catch can but as a noob to the 18t im a little unsure
im about to buy this..http://www.ebay.co.uk/itm/Black-Alloy-Oil-Catch-Tank-Can-10mm-15mm-Inlets-VW-Polo-Golf-Bora-Jetta-GTi-/360442541907?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Car+Make%3AVW%7CModel%3AGolf&hash=item53ec0cb753
but what else will i need i.e size of pipeing
the big thing i have is im unsure what pipes i remove and what pipes i block off also where the new pipes will go
any pics would be great i have the agu engine 99 model
i have just replaced the elbow under the tb at a cost of £25 can i still use this with the catch can??
« Last Edit: 19 March 2012, 17:22 by wolfie1981 »
Offline Chris#101
Re: oil catch can install please help
« Reply #1 on: 19 March 2012, 18:00 »
youl need around 2 meters of 19mm Id heat/oil proof hosing
19mm T piece
x2 19mm-15mm reducers
small lenth of 15mm id heat/oil proof hosing
 :smiley:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline cullygti
« Reply #2 on: 19 March 2012, 18:31 »
if it does not come with 19mm fittings you will also need 15mm pipe closest i found was 16mm which should be fine  :smiley:
i will be putting a few pics up of my install later as i had same can but modified it  :wink:
Offline wolfie1981
« Reply #3 on: 19 March 2012, 18:34 »
how about fitting it???
what pipes come off the car and which ones do you need to block up
any pics
Offline Dave_IOW
« Reply #4 on: 19 March 2012, 18:36 »
Fisher price version lol...
Red = from 90 degree bend
Green= from rocker
Blue = from T piece
Pink = Back to TIP
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jockgti
« Reply #5 on: 19 March 2012, 18:38 »
same can i have,get 16mm pipe about 1mtr and 2mtr 19mm also get 1 19-16mm reducer,on one of the 15mm outlets wrap some electrical tape round it to make it wider for the 19mm pipe,i made my own bracket for it and attached it to the bracket that holds the 249 valve underneath
Offline wolfie1981
« Reply #6 on: 19 March 2012, 18:47 »
thanks guys
 are there any pipes once i take the old ones off that will need blocking up
jockgti
« Reply #7 on: 19 March 2012, 19:03 »
i have an aum engine code and had to block off 2 under the inlet manifold,basically everything goes except the plastic elbow you've replaced already,all the stuff circled is what i removed
Offline Dave_IOW
« Reply #8 on: 19 March 2012, 19:10 »
1 to block off for AGU..
Nice bay Jock  :afro:
Offline wolfie1981
« Reply #9 on: 19 March 2012, 19:29 »
where abouts is the 1 on the agu i need to block off
