Author Topic: PLEASE HELP URGENTLY!!!!!!!!!  (Read 2909 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 17 March 2012, 14:41 »
taking the sump off and the last bolt remove in by the gearbox has rounded off and cant get it off,any HELP will be very very greatfull.
THE BOLT THIS WELL STUCK AND VERY TIGHT IS THERE A SPECIAL SOCKET I CAN GET  :undecided:
« Last Edit: 17 March 2012, 19:33 by (shakey) »
Offline rio_gti
Re: HELP URGENTLY!!!!!!!!!
« Reply #1 on: 17 March 2012, 14:48 »
10mm socket or I think 6mm alen key should do it
Offline (shakey)
« Reply #2 on: 17 March 2012, 14:52 »
no good m8 tryed that already its on a slight angel and socket wont quite fit on and its rounded the bolt head and the allen has rounded to as the bolt is so tight  :angry:
Offline (shakey)
Re: PLEASE HELP URGENTLY!!!!!!!!!
« Reply #3 on: 17 March 2012, 19:33 »
BUMP STILL NOT GOT IT OFFFFFF HELPPPPPPPPPPP
Offline houston
« Reply #4 on: 17 March 2012, 19:34 »
use a smaller socket and hammer it on, obviously replace the bolt
Offline (shakey)
« Reply #5 on: 17 March 2012, 19:40 »
its hard to get a smaller socket as its on a slight angel so the socket wont sit right.
Offline jonnyturbo
« Reply #6 on: 17 March 2012, 19:43 »
What about a bolt extractor socket
Offline (shakey)
« Reply #7 on: 17 March 2012, 19:45 »
that might work will have to get 1 tomorrow i have spent allday trying to fricking bolt out  :angry: :angry:
Offline opel
« Reply #8 on: 17 March 2012, 19:46 »
if not smack a multispline bit into it and try to get it out if not it may be a gear box out job to get to it properly
Offline houston
« Reply #9 on: 17 March 2012, 19:49 »
put the socket on extension bar and hit it that way, if by angle you mean you have to put socket on at angle?
other than that other choice is weld another bolt to it, mole grips, grind it and use stud extractor for remaining bit
