Author Topic: 99 agu overfueling?????  (Read 1903 times)
Offline badboybunty
« on: 17 March 2012, 08:14 »
hi all i have searched but cant find what im after
im not sure but think my car is overfueling
its on 150k with r32 style milteck it pops and bangs when changing gear i have heard that the non-res milteck does this however it has the cat on at the moment and hasnt been mapped and i only can get get 30 mpg average driving like a grandad on the motor way to and from work 25 mile trip there.
it runs on v power
only reason i ask is cause of the mpg and the fact that i polished up the tailpipes 5 days ago and now there black as the ace of spades??
what can be causing this??? no fault codes but have notised that if i rev drop off and put foot on the pedel quickley there seems to be a delay before revs pick up same when driving can here the turbo spooling at about 2k but delays in pulling till 3k when u get a sudden rush! i didnt think there is lag on a baby ko3 (have got a ko3s to go on)
 car seems sluggish when driving up the gears
im planing on having my 3 inch decat fitted soon is it worth buying a new lamba?
i have tryed to give as much info as i can but newish to newer turbo car with more sensors bit of a old skool turbo boy lol
if anyone could help be mucho greatful liam :smiley:
« Last Edit: 17 March 2012, 08:16 by badboybunty »
Offline jamie1989
Re: 99 agu overfueling?????
« Reply #1 on: 17 March 2012, 08:58 »
Possibly a boost leak, get a smoke test done buddy.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline houston
« Reply #2 on: 17 March 2012, 09:55 »
mine is doin exactly the same since i changed the turbo, but i also had to replace the n75 valve too, so im looking at a boost leak or a broke valve, maybe yours is similar.
know what you mean about sensors as well, i still dont know what half them do
Offline badboybunty
« Reply #3 on: 17 March 2012, 10:08 »
Well just having a look at my pipes few are worn but don't seem split can the diverted valve cause this is standard apart from air filter but get lots of compressor stall which suggests the dv is fubar ??
Offline badboybunty
« Reply #4 on: 17 March 2012, 10:19 »
Found split pipe runs from inlet manifold by the dipstick to a t piece can this cause it ??
Offline jamie1989
« Reply #5 on: 17 March 2012, 11:16 »
Show us a picture of the split hose mate.
Any sort of split on any boost pipes will cause you issues.
Offline houston
« Reply #6 on: 17 March 2012, 11:23 »
yes that one will lose boost from the manifold, look on ebay and you can get a silicone one for about £20, nice and easy to change too
Offline badboybunty
« Reply #7 on: 17 March 2012, 11:24 »
Offline rio_gti
« Reply #8 on: 17 March 2012, 11:28 »
Ditch it all(the pcv) and get a catch can in there u can get all the bits for about £60  :wink:
