Author Topic: 380cc injectors, Meth/water injection, highflow manifold.....  (Read 7791 times)
Offline Chris#101
Right ive got a few tricks up my sleeve :smug: but im needing help  :smiley:
*Im after a set of 380cc injectors... are there any vag cars that run these standard that would fit the golf 1.8t fuel rail etc!?!?
*Water meth injection, Who sells the cheapest kit these days!? OR has anyone got a list of things needed to D.I.Y the job?
*Are there any high flow/large port exhaust manifolds out there for the golf 1.8t!?
thanks in advance
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
jamie16v
been looking for a k03s type manifold myself.. cant seem to find one.. :drool:
Offline houston
http://www.tsr-performance.com/webshop/parts-by-category/exhaust-manifolds/tubular-turbo-exhaust-manifolds/k04-high-flow-tubular-manifold-tsrk04mani-suitable-for-all-1-8t-k04-turbo-cars-such-as-audi-tt-and-leon-cupra-r/
not cheap tho, and not worth it for a k03-4 as the gains just arent there, but im assuming if your after injectors that size and a meth setup then your not fitting an oe turbo?
Offline Chris#101
That is one nice looking manifold but Wayyy out of my budget  :shocked:
Im looking into buying a K03s hybrid, k04-001 turbine with K03s compressor  :drool:
But Ive been advised il need all mentioned just struggling to find anything  :sad:
jamie16v
the manifold above is for k04-023 turbos not k03..
Offline Chris#101
doesnt matter either way as I certainly wont be buying it  :grin:
Found a possibility..
http://www.fr-rtuning-shop.co.uk/index.php?_a=product&product_id=1844
Anyknow know much about them?
thanks  :smiley:
Offline shaft69
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline shaft69
meth inj awesome i run devils own kit brilliant, been put of buy cast manifold as hear they crack looking out for tubular one but no luck for ko3s. All seem to be for k04's, i got some saab yellows 3" housing all ready to be fitted. Need power run see what its running at 1st.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Chris#101
cheers for the link bud  :wink: now for the questions  :shocked: :grin:
Did you have the meth kit from new?
Where did you get it from
Was it hard to fit?
Is one of these it?
http://www.alcohol-injection.com/en/169-golf-jetta-passat-18t
Do you know what Flow rate the Saab yellow injectors are?
cheers dude  :smiley:
Offline Toby
  • Car - less
iv got some ford red tops - cant remmeber the cc but there good for a ko3s set up.
Currently down under
