Author Topic: 380cc injectors, Meth/water injection, highflow manifold.....  (Read 7808 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
think there around 330-360cc injectors toby.
Offline Toby
  • Car - less
ill find out tomorow when i get them back  :grin:
Currently down under
Offline Hulmie
was thinking of popping down again but got some stuff to do up here. Enjoy the drive home and dont blow her up.
Offline Toby
  • Car - less
shame!  :cry:
yeah ill try not to  :grin:!
got a very good day out next saterday! REVO day!  :shocked: :rolleyes:
Offline Chris#101
IF you could bud that would be fab.... Or even better ask Nick if they be useable in Chris Elvin's Auq 180 set up, as Il be ringing them tomorrow
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Toby
  • Car - less
wil do buddy!
Offline shaft69
Yellows 350ish if i remember rightly, got some genesis ones my nephew sent me from states but there 680cc so wont be using them.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Toby
  • Car - less
i need some 440's  :grin:
Offline shaft69
cheers for the link bud  :wink: now for the questions  :shocked: :grin:
Did you have the meth kit from new?
Where did you get it from
Was it hard to fit?
Is one of these it?
http://www.alcohol-injection.com/en/169-golf-jetta-passat-18t
Do you know what Flow rate the Saab yellow injectors are?
cheers dude  :smiley:
Got mine from new  and piece of cake to fit, just run water feed through chassis leg from back to front, pump in wheel well rest where you want. Fitted boost gauge to know what psi pumps starts to run.
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline Chris#101
Was it hard to fit?
Is one of these it?
Orite nice  :smiley: is the electrical side of things easy to do? can you adjust when it needs to be spraying?
Where did you get yours from ?
