Author Topic: Low throttle misfire 8v digifant  (Read 1314 times)
Offline eightvalve
« on: 27 May 2005, 09:46 »
Help! Has anyone ever had this problem? I get a misfire/hesitation at low throttle opening, i.e. when cruising at part throttle . If I open the throttle further I can drive throught it and it goes away.  I thought it was electric so I have renenwed the plugs, leads, distributor cap and rotor and the coil.  It seemed to improve things but its come back again, though not as bad.
Any ideas?  It's a 1989 8v digifant.
1989 Mk2 8v
Offline Gambit
Re: Low throttle misfire 8v digifant
« Reply #1 on: 27 May 2005, 10:05 »
did u try replacing the blue temp sensor and resetting the ECU? there is a sticky at the top of the forum which details this
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #2 on: 27 May 2005, 10:14 »
On top of that what fuel are u using - I had a similar problem and practically replaced the whole fuel and electrical system!
At the same time I had put a tank of BP ultimate in instead of Optimax as per usual - when I changed back I never had the problem again ...  :laugh:
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline eightvalve
« Reply #3 on: 27 May 2005, 16:38 »
I had been using 95 octane so I tried a tank full of super but there was no change. Anyway, I had been using the same fuel for ages and never had a problem.
What would changing the temperature sensor do?
1989 Mk2 8v
