Author Topic: Hissing vr6  (Read 3303 times)
Offline bmotormad
Hissing vr6
« on: 14 March 2012, 21:15 »
Hi all,
Just put a vr6 in my mk3 cabrio. went fine until i tried to run it !!!
when ignition was switched on the fuel pressure regulator was whistling dixie, luckily i just happen to have another vr6 so swapped it over and now it sounds like its venting somewhere else.
It will turn over and fire but then dies, leave it a few seconds and it will do the same.
any help would be great as im out of idea's
Thanks
Been doing more research and it seems the ecu has an immobiliser !!!
« Last Edit: 14 March 2012, 22:34 by bmotormad »
Offline Diamond Hell
  • Opinions я Us
Re: Hissing vr6
« Reply #1 on: 14 March 2012, 22:34 »
Sounds like an immobiliser fault.
Or if the fuel pump is running the whole time it's possible you've not earthed the ECU correctly and blown that.
Offline bmotormad
Re: Hissing vr6
« Reply #2 on: 14 March 2012, 22:37 »
pump is running all the time but wires were all in before i attempted to start.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Hissing vr6
« Reply #3 on: 14 March 2012, 22:39 »
ECU does not have immobiliser like on MK4s but you need transponder and chip from donor car .. just incase u not done that
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline bmotormad
Re: Hissing vr6
« Reply #4 on: 14 March 2012, 22:40 »
thought i swapped everythin over, what does it look like ?
Offline Peej1981
  • Its Whats Under The Hood That Counts........
Re: Hissing vr6
« Reply #5 on: 14 March 2012, 22:54 »
The transponder and chip are built into the key, did not not get a set of keys with the doner car?
www.bombercountydubs.co.uk
Offline bmotormad
Re: Hissing vr6
« Reply #6 on: 14 March 2012, 23:05 »
havent swapped the barrel  :embarassed:
Offline topher
  • Administrator
  • fully functioning
Re: Hissing vr6
« Reply #7 on: 14 March 2012, 23:10 »
no need to swap the whole barrel you can just take the immo pickup ring off the donor... which plugs into the immo box behind the dash which i reallllly hope you haven't sent to the scrapyard!
Offline Peej1981
Re: Hissing vr6
« Reply #8 on: 14 March 2012, 23:13 »
As topher said and lets hope you havnt scarped the doner car  :shocked:
Offline bmotormad
Re: Hissing vr6
« Reply #9 on: 14 March 2012, 23:17 »
nope still in my scrap yard aka the front garden!!!
so is it the brown ring that plugs into the brown box? i suppose that means i will have to pull the dash out  :cry:
