Author Topic: Hissing vr6  (Read 3304 times)
Offline bmotormad
Re: Hissing vr6
« Reply #10 on: 15 March 2012, 00:01 »
will try tomorrow if i get a minute, thanks for the help.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: Hissing vr6
« Reply #11 on: 15 March 2012, 10:47 »
Yea it's the brown ring u need plus the chip out of the donor key (replace the chip in your own keys for the one from the donor car  :wink:)
And as toph says u need the little immob box that the brown ring plugs into
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Diamond Hell
  • Opinions я Us
Re: Hissing vr6
« Reply #12 on: 15 March 2012, 13:39 »
It's like an instant expert on engine conversions.  :rolleyes:
Not that the ECU's immobilised you understand, it's just that it has an immobiliser.  :huh:
pump is running all the time but wires were all in before i attempted to start.
This sounds like a wiring fault before you get to the immobiliser problems.  Even immobilised the pump should prime and then shut off.  It should not run constantly.
Sounds like the wiring's a long way off running yet.
Re: Hissing vr6
« Reply #13 on: 15 March 2012, 13:50 »
As DH said if the pump is running all the time you have a wiring issue or maybe even a blown ecu, I do not think you have an immobiliser issue
Offline madmanluke
Re: Hissing vr6
« Reply #14 on: 15 March 2012, 15:07 »
Do you use a third party alarm? I.e CLifford etc?
Installers tend to wire in the fuel pump immobiliser in such a way that it WILL prime constantly when the alarm is disabled and the ignition is on.
If you do not have an alarm installed, from factory a OBD1 engine will prime then shut off after a few seconds. An OBD2 motor will NOT prime until the engine is turned over.
If your saying you can here a hiss, I would double check all of your vacuum pipes. There is one hidden under the throttle body to the left that is sometimes missed. This along with the vacuum that leads to the fuel pressure regulator is worth checking.
Offline bmotormad
Re: Hissing vr6
« Reply #15 on: 15 March 2012, 21:52 »
thanks for all the info, not had time to get on it today  :sad:
there was a black box in the car (vw/audi stamp) which was a total mess i traced back to a bare wire connection (went to starter), cut it out and fed a new wire to the ignition (where the other bare wire connection was!!)
Engine is late obd2
  • Opinions я Us
Re: Hissing vr6
« Reply #16 on: 16 March 2012, 12:59 »
Sounds like some c*nt alarm installer's been in there, screwing the wiring up for you.  :rolleyes:
Offline SoundillusioN
Re: Hissing vr6
« Reply #17 on: 16 March 2012, 13:07 »
Grrrrr. Strip it all out and start again!  :grin:  :lipsrsealed:
Offline danny_p
Re: Hissing vr6
« Reply #18 on: 16 March 2012, 22:47 »
grrr  aftermarket immobs.   useless fecking things.
immob issue ~( factory  ) should start abd cut after 3 seconds or so.      ether swap the barrel, immob box and chip over in the key.
or just swap the box plug the other rf id loop in and bung the donor key in that loop to prove the system.
it is easyer the just to vag com it tho
all the VW's have gone bar 1.
Offline bmotormad
Re: Hissing vr6
« Reply #19 on: 19 March 2012, 14:57 »
Ok, swapped over key, ring and box while i was changing the clocks  :smiley:
think the ecu is fooooked tho  :cry:
I had a search around the earths and had missed the one from the battery, which connects under the battery tray (not sure which bolt it should go on front or back?), don't know if this made any difference? have checked earths to fuse box 4 times now!!! not sure why all the wires are the same each time  :grin:
will have to find another ecu as i think the other one i have is for a 2.9.
Pump still running constant  :angry:
only swapped engine loom and pump was running fine before (2.0 8v) so must be ecu.
