The garage
MK2 Golf GTI Head Rebuild
Topic: MK2 Golf GTI Head Rebuild (Read 3435 times)
chrisfletcher
14 March 2012, 21:06 »
Hello all,
I have a week of work now and want to rebuild the head on my motor.
Just need to know what parts would i need to buy?
Chris
clipperjay
Re: MK2 Golf GTI Head Rebuild
14 March 2012, 21:41 »
what was wrong with the old one?
http://www.golfgtiforum.co.uk/index.php?topic=170521.0
http://www.golfgtiforum.co.uk/index.php?topic=55336.msg427955#msg427955
The Mighty Elvi
I'm better than you today.
14 March 2012, 21:44 »
Well.. How hardcore do you want to go?
valves.
Valve springs.
oil stem steals.
volume matching.
tappets.
Smoothing the combustion chamber.
Porting & Polishing.
Compression test.
etc..
chrisfletcher
14 March 2012, 21:46 »
Gives me something to do
I was looking to do a port and polish
and what ever is needed really.
Chris
The Mighty Elvi
14 March 2012, 21:47 »
Chris, If you are new to this, watch ALL the videos:
HERE
NB: 8v just had 8 fewer valves.
chrisfletcher
14 March 2012, 21:49 »
saw these a while back, that what makes me think i can do it :p
Just really wanted a parts list i can take to gsf and go... "oi, gives me these"
Chris
The Mighty Elvi
Reply #6 on:
14 March 2012, 21:51 »
Quote from: chrisfletcher on 14 March 2012, 21:46
Chris
Ah ok.
Well you want to port and polish the exhaust manifold and maybe the combustion chamber (the shallow bowl where the valves rest)
And you want to roughen up the inlet manifold. This may seem counter intuitive, but in fact you need the rough surface to aid the mixing of the fuel and air before it enters the cylinder.
The smooth surface of the exhaust manifold speeds the release of the exhaust gasses.
chrisfletcher
Reply #7 on:
14 March 2012, 21:54 »
awsome cheers man, makes sense actually cause obviously turbulent air will make it mix
SCIENCE!
The Mighty Elvi
Reply #8 on:
14 March 2012, 21:56 »
As a must. Valve stem oil seals.
Valves, unless bent, can be cleaned up and reground.
Springs
Should
be ok. Line them up and put a rule across the top. If they're are all the same height, then their rates should be ok.
Tappets as well.
chrisfletcher
Reply #9 on:
14 March 2012, 21:58 »
How do i go about the regrounding?
The garage
