Author Topic: what spark plugs to use in my 99 18t gti  (Read 1714 times)
Offline wolfie1981
« on: 14 March 2012, 08:51 »
im about to change the plugs in my car not sure what to buy and the correct plugs that fit all the mupputs in helfords dont seem to have a clue.
after some reading some say use bosch super 4's others say ngk
any help would be great :smiley:
Offline Dalo Harkin
Re: what spark plugs to use in my 99 18t gti
« Reply #1 on: 14 March 2012, 08:54 »
Is it standard or mapped?
if standard Bosch Super 4's or NGK Platinum
if mapped I use Denso IK22's I think they are called but they are £40 a set  :sick:
Offline wolfie1981
« Reply #2 on: 14 March 2012, 09:09 »
not mapped yet but soon will be like in the next 2 weeks
do you know the model number for the plugs i need??
Offline cullygti
Offline richw911
« Reply #4 on: 14 March 2012, 10:47 »
NGK which is what VW use dont get them from VW though as per this thread
http://www.golfgtiforum.co.uk/index.php?topic=87370.0
Offline navmk4gti
« Reply #5 on: 14 March 2012, 10:53 »
I use bosch super 4s too :smiley:
Offline palmtree
« Reply #6 on: 14 March 2012, 11:34 »
i'm using NGK platinum PFR6Q
Offline Scott D
« Reply #7 on: 14 March 2012, 16:48 »
using NGK PFR7Q's which are a stage cooler than the 6Q's previously had in.
the PRF6Qs I believe are standard fit replacements for AUM/AUQ and 225 1.8t's.
Did occasionally get misfires coming off throttle but heard no pops or bangs  :grin: since changing to the 7Q's, seems to running be a lot smoother as well.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline palmtree
« Reply #8 on: 14 March 2012, 19:39 »
What power are you running?
My ARZ runs fine on the 6Q's but might try the colder 7Q's next time there due a change
Offline wolfie1981
« Reply #9 on: 14 March 2012, 20:03 »
im running standard but not for long having a remap in two weeks time
going to do the plugs and oil tomorrow but not sure what plugs still to buy i was thinking on getting the bosch super 4's
